Ford Racing Lowering springs
Old Apr 26, 2005 | 04:06 PM
95mustangkid's Avatar
ok i was going to go with the ford racing lowering springs on my 1995 GT and they have i think 7 different types an A to G all for 94-04 and they all have to do with weight. and i was wondering if anyone could help me with which one i should order.
Old Apr 27, 2005 | 01:26 PM
UA2k1GT's Avatar
C springs will be like Steeda springs. Flat, stiff rate up front.
I think it was the B springs that I was going to get, more like the Eibach pro kit, with a progressive rate up front.
Old Apr 27, 2005 | 01:54 PM
IIGood's Avatar
C Springs seem to be about the most popular. Stiffer up front, and about the same as stock out back.
IIRC, the rates for the C springs are 650/200-300 (front/back). Compared to a stock GT's suspension of 400/210. Also, I understand the Terminator Cobras come with 600 all around...
I've got the C-springs on my GT, and they're pretty good. Gives it a subtle drop, can still clear speed bumps and such , and handles a little better vs. stock. The car doesn't lean as hard in turns anymore, can take them a little quicker.
Price is decent too...paid $129 shipped from GEFRacing.com.
Old Apr 27, 2005 | 04:31 PM
ok cool thanks. how much does it usually lower it. i know they say its about a 1" to 1" 1/8.
Old Apr 29, 2005 | 10:41 AM
CP94GT's Avatar
Be careful, and keep a lookout for any funny noises coming
from under the car. The '94 and '95s had issues with the
drive shaft not having adequate clearance in the tunnel
after being lowered. There is potential for the drive shaft
to rub the parking break cables, and when it finally gets them
worn down enough it will start on the bracket that the cables
attach to. We were able to fix the problem by bending the
bracket up closer to the underside of the tunnel and tack welding
it in place. Unfortunetly this was after the bracket had begun
tearing a hole in the underside of my car.
Old May 28, 2005 | 07:06 AM
flashbang756's Avatar
Yeah, what he said!! But, from what I understand, the B springs give the same drop but ride a little better. The only thing with mine and the C springs, is on some bumps, I hit the rear bump stops pretty hard. I need to shave them down a little I think.
Old May 28, 2005 | 07:08 AM
I've heard of this. But not that much from people with Ford Racing springs. Mostly from people with springs like Eibach Pros and others that lower the car alot more than the Ford springs.
Still, good info and something to watch!
Old May 28, 2005 | 07:11 AM
And, I don't know if this helps but, here's some pics of mine with C springs to give you and idea.
Old May 28, 2005 | 08:36 AM
aaron95stang's Avatar
that is a sweet looking car Brad. Do you have anymore pics?
Old May 28, 2005 | 11:14 PM
Sure, thanks for the compliments! Here's some more...
Old May 28, 2005 | 11:15 PM
And the Mexican block based 331 that's getting dropped in....
Old May 28, 2005 | 11:16 PM
A pic of the mock-up of the turbo kit for cutting........
Old Jun 22, 2005 | 06:23 PM
jimmyman95's Avatar
hey,
I agree with aaron, thats a sweet car Brad. I was wonderin about that hood. Where did you get it and how much was it? And also have you had any problems with the rubbing like was talked about?
Old Jul 5, 2005 | 11:19 AM
Originally posted by jimmyman95@June 22, 2005, 7:26 PM
hey,
Hmmm, sorry. I'm seing this a little late.
The hood is a H.O. Fibertrends 2.5" Cobra R. (They're the same people that made the production hoods on the '95 Cobra R and the '00 Cobra R) And to be honest, it's been awhile since I bought it and I don't recall the price. I bought it from Paul at www.svpu.com. He's a moderator here.
As far as rubbing, are you talking about with the emergency brake cable?? I don't have that with my "c" springs. I've only heard of that problem with other companies springs which lower the car more than the "c" springs do. Like Eibach pro's etc. The only problem I have is hitting the bump stops on the rear end when I hit bumps. But I'll be solving that soon by shaving the bump stops a little.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
RocStar69
Aug 21, 2015 07:33 AM
