Engine Swapping
Old Jan 29, 2005 | 03:27 AM
Mestizo's Avatar
Ok,
I've been thinking of buying a second car.....a project car, of course. I had a few questions regarding engine swaps. I'm looking at getting a SN-95 GT, but I'm considering swapping the engine.
I know that the Mark VIII and the 96-98 Cobra have virtually the same engine(except: intake, exhaust cams, and crank). I was looking today, and it seems the Mach 1 and Mercury Marauder have a similar if not the same engine, correct?
I'm just wondering if there are any other engines that are similar or shared with the Mustang..........4.6-5.0L v8s of course. Continental? Town Car?
Also, would taking the path of placing a Lincoln/Mercury engine be better than buying a direct Mustang or Cobra engine? I know that upfront price goes down, but would aftermarket support be affected.
Lastly, which would have a higher insurance rate Mercury/Lincoln or Cobra/Mach 1?
Thanks!
Old Jan 29, 2005 | 10:58 AM
Fordracing200's Avatar
Put a Navigator motor which is essentially a Cobra R motor in it.
Old Jan 29, 2005 | 12:40 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
01+ Crown Vic's use the same 4.6L as 99+ mustangs. Only difference is cams I believe and maybe the upper intake. Previous 4.6L crown vics used the 4.6L minus the PI heads/intake.
Old Jan 29, 2005 | 12:41 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
No its far from a cobra R. The R is a DOHC 5.4L, but its hand built, has completely forged internals, aluminum block. Also has custom designed cams in which you can not buy as well as a completely custom intake that ford will not cast anymore.
Old Jan 29, 2005 | 07:05 PM
Mestizo's Avatar
Was I correct about the Mach 1 and the Marauder having the same/similar engine?
Old Jan 29, 2005 | 08:16 PM
Similar. Both have a 4.6 4 valve. One has a shaker one doesnt. I dont think their are any more differences, if there is there are only a few.
Old Jan 30, 2005 | 08:48 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
There is a difference in the intake design (varied runner lengths between the 2) also there is a cam profile difference. Also the 5-speed mach1 motors have a forged 8bolt crank as where the auto cars have a 6-bolt cast crank.
Old Feb 4, 2005 | 11:39 PM
Mestizo's Avatar
Thanks for the info!
I figured the crank would be different. Any clue on which insurance rate would be higher?
Mercury engine or a Mach1 engine?
Lincoln Mark VIII engine or a Cobra engine?
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Ray11
Sep 25, 2015 12:43 PM
