Electrical car cuts out.
Old Sep 5, 2023 | 10:40 AM
Dleeuwendaal's Avatar
So I forgot the ignition on overnight and battery drained all way down. Had to recharge then it ran for a number of weeks. I fear I burn some components. Need assistance it cuts out while driving then does not want to start for 5 min and then starts and will cut out again. Besides the constant control relay module. What else could be the problem?
Old Sep 5, 2023 | 10:49 AM
05stangkc's Avatar
So, I See From Your Profile You Have a 1995 Mustang GT. Since You Mention it Have You Replaced CCRM????
Have You Checked For Trouble Codes With a Scanner??
You Say It Cuts Out, When, All the Time or Only When Trying to Accelerate??
When It Won't Start For 5 Minutes Have You Checked During That Time For Spark or Fuel Pressure??
If it Ran Fine For A Couple of Weeks Before this Issue May Consider Bad Fuel, Plugged Fuel Filter or Unrelated Issue!
KC
Old Sep 7, 2023 | 01:02 PM
KC
So I'm waiting for a replacement ccrm so will try that. Fuel and spark are good and scanner only has. An issue with o2 sensor and it is disconnected for a number. Of years already. Thanks for feedback.
Old Sep 7, 2023 | 01:32 PM
05stangkc's Avatar
If you Have an O2 Sensor Issue I Would Be Curious if It is Running Too Rich Or Too Lean. Spark Plug Replacement and Or Inspection Then Repairing o2 Issue May Be a Good Thing to Address!
Mgb,
KC
adidasoccer01
1994-2004 V-8
May 5, 2012 01:02 PM
harristotle
Dec 12, 2011 08:46 AM
cntchds
Mar 7, 2011 10:58 PM
StangFreak
Sep 9, 2008 07:58 AM
hatchttu
Dec 31, 2007 12:50 PM
