Eibach: Prokit or Sportline
Old Mar 28, 2005 | 08:46 PM
will's Avatar
I'm going to be lowering the '04 GT this summer. I'm just in a bit of an indecision whether to get the Pro Kit or Sportline.
My only hesitations toward Sportline are that the car may scrape A LOT. If that is the case then I'll just get the Pro Kit as it seems to be low enough. I just can't get enough of the look of 'stangs with the Sportline kit.
Any help is greatly, greatly appreciated!
Old Mar 29, 2005 | 05:56 PM
larlar's Avatar
i have a 99 gt and im doing the same and was told the pro series is the way to go good luck..larlar
Old Mar 29, 2005 | 06:39 PM
will's Avatar
that sounds about right. i was questioning how low it needed to be. especially since i'll probably want to install the mach chin spoiler sometime in the future. sportline seemed to be a bit low for that.
Old Mar 30, 2005 | 01:19 PM
UA2k1GT's Avatar
you will still scrape with the pro kit.
Old Apr 9, 2005 | 04:07 PM
mr. jones's Avatar
I have the pro-kit on a 1998 gt look great not to low and rice looking.
I put springs, struts, stocks, poly bushings in the front control arm, rack off-center bushings for bump steer, new ball joints, swap bar poly bush and poly upper bush in the diff with a new upper control arm that has a sperical bearing at the body tie point.
I used the cam alignment bolts to set frontend and standard stut mounts at the tower.
Good street setup without noise and rough ride. Now I will be replacing the lower control arms and a weld in body stiffner and the suspension is done for a long time.
AJ_Trevino15
Sep 28, 2015 07:51 AM
holeshot
16
Jan 2, 2009 12:02 AM
kaihila9
05-09 Exterior Modifications
Jul 9, 2008 05:05 PM
