Durability
Old May 24, 2004 | 12:43 AM
Mestizo's Avatar
Ok,
We all know the upside of owning a Mustang, or any other high performance car, however sometimes we forget the downside. I've never owned a Mustang, and I'm looking at several cars; included in those cars are the 2005 and the 03-04 Mach 1.
However.......no one owns a 05 yet and Mach 1's are very limited, so my question is for the V6, GT, and Mach 1 owners.....over the last couple years what problems has your Mustang presented, and how much were the repair bills? Simply put I'd like to know the car year, miles, problems, and cost.
I'd like a lot of replies, and honesty.....of course.
This will have a heavy influence in my decision.
Old May 24, 2004 | 05:40 AM
Pastjcprez's Avatar
2003 GT-- 9 months old-- 33000 miles-- no problems
Old May 24, 2004 | 07:23 AM
UA2k1GT's Avatar
2001 GT - 43,000 miles
IAC Valve failed at 25,000 miles, fixed under warranty, but they are cheap to replace, around $50 or so.
Other than that, nothing aside from the typical squeeks, rattles and twisted up seatbelts.
Probably anywhere from 75 to 100 1/4 mi. passes also.
Old May 25, 2004 | 12:22 AM
Lirathal's Avatar
I personally don't own my mustang yet, but my friend's '99 had two new engines, and tranny, ABS problems along with clutch issues. oil loss
My other friends 2001 .. nothing so far
2003 - Loosing oil from engine ... bags on it
another 99 ... loosing oil (black pipes) - babies it.
*shrug*
Nathan
Old May 25, 2004 | 12:41 AM
Mestizo's Avatar
Man it sounds like with a Mustang......the whole thing is wrong or perfect. Kinda weird.
It also sounds like the 97 and 99 were terrible years for the Mustang repairs.
Old May 25, 2004 | 01:22 AM
2001GTMILT's Avatar
2001 GT = Burned window motor, fixed under warranty. And nothing else. 22,000 Miles.
The thing is some mustang fall into the hands of people who think thier mustang is indestructible. They beat and beat on it like theres no tommorow. Any car will have issues under these circumstances. If you get an auto get a tranny cooler. Cheep and effective way to get you tranny to last longer.
Old May 25, 2004 | 06:33 AM
Goat Rider's Avatar
62000 mi. on a 99 V6 and the only thing I can say is the alignment is a little fragile.
Old May 25, 2004 | 06:47 AM
gokbgo's Avatar
02 GT, 28,000 miles, no probs, except for the nagging seatbelt that occasionally won't retract.
Old May 25, 2004 | 09:19 AM
mauricio's Avatar
I have a Bullitt 2001 40000Km. Beware of ignition problem.
They had to replace 4 COP (coil on plugs) so far. After looking other forum, there is a know problem with those parts.
Old May 25, 2004 | 11:51 AM
G8trStang's Avatar
2001 GT Auto: 42000 miles AOD
torque converter went out at 30k
Torque converter is acting up again at 42000
I'm actually picking my car up at the dealership later today for the repair.
BTW, both were covered under the warranty. Ford tech said that if it goes out again, they'll put a new tranny in for me.
If you buy a mustang, one tip, GET A MANUAL TRANNY!!!
This is my second mustang, 1st was a 95 6cyl, the torque converter in that baby went out as well, but it was at 75000 miles. It still drives at 130000, just shakes sometimes when gears are shifting.
Also, the head gasket and 2 heads were warped at ~35000 miles, repaired by ford under warranty.
i loved by 95 6 banger, did some crazy $hit!! BUT DON't by a 3.8L 6cyl!! horrible engine design!! :nono:
Old May 25, 2004 | 11:53 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
1996 4.6L 4v... 114,000 miles still going strong.. about to have to replace the water pump. Also had to replace plug wires, plugs, coil packs and IMRC controller all between 65-70k miles.. these arent an issue on any newer stang though.
Old May 25, 2004 | 12:16 PM
Mestizo's Avatar
Everything sounds like its covered under warranty.....what is the warranty: 5yrs? 100K?
Old May 25, 2004 | 12:22 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Sorry none of mine was under warrently.. factory is 3yrs/36k with options for extended.
Old May 25, 2004 | 12:57 PM
Mestizo's Avatar
Yea, somethings are to be expected .....on my Civic I replaced the water pump after 6 years, so that's not too bad.
Old May 25, 2004 | 02:52 PM
UA2k1GT's Avatar
what the heck do you do, manually upshift and downshift all the time, or keep the car in 2nd to keep the rpms up?
i find it hard to believe both of your stangs have had TC problems, especially 2 new ones in a row.
Old May 25, 2004 | 02:53 PM
UA2k1GT's Avatar
*shrug*
Nathan
are black pipes the only sign of losing oil? or does your friend actually check the oil regularly and have to add?
my pipes are black too, but its because my car is rich as crap and i run an offroad h
Old May 25, 2004 | 04:00 PM
Zastava_101's Avatar
TMS Post # 1,000,000
Serbian Steamer
2000 Mustang V6, 5-speed manual
currently 23,000 miles
1 problem recently when theft system was turned on, so I had to tow Mustang to Ford dealer, everything on the car was blocked. It was about $300.
Old May 26, 2004 | 06:18 AM
G8trStang's Avatar
I honestly don't do anything, to my new stang. i don't go to the track, the worse thing i probably do is occasionally floor the car because some idiot won't let me merge.
For my 95 6cyl, (which was my first car when i was 17), i sorta beat it up pretty bad; i had a pretty bad lead foot attached to me, so i wasn't really surprised that so many things went wrong. However, this new 2001 GT i have, i've babied (promised to do everything i can to prevent what happened to the first one), I even paid for the rip-off 30,000 mile Ford maintenance package. :bang:
Thats why i'm so surprised that its gone out twice on me. I spoke with the Ford tech and he said its very common on a Ford AOD for the TQ to go out. :notnice:
Old May 26, 2004 | 06:23 AM
G8trStang's Avatar
BTW, my sister had a 94 civic, she's had to replace the CV joint 3 times! also, a piston blew out of the side of the engine because she didnt know the head gasket was broken. Coolant was leaking into her motor and was rotting everything.
She purchased a 2001 accord special edition, the check engine light is already on, so much for Japanese Quality.
Old May 26, 2004 | 11:21 AM
Mestizo's Avatar
I've been lucky with engine problems, other than a radiator.
This is another Mustang question: From what material is the radiator made?
My Honda is a mixture of metal and plastic, and after 10 years in the Texas Sun it had a pinhole leak. The people at the shop said it was the plastic that cracked.
I was just wondering if a Mustang has more(or is all) metal, because my raditor will give me problems if I'm sitting in a fast food line for long periods of time....but once I'm on the highway....the tempature gauge goes back down. I know the reason for this, I just don't want to deal with it on an American car.
