driver side seat won't over forward or back
Old Mar 13, 2014 | 11:28 AM
kathrync9311's Avatar
You can hear the motor working on the seat. Could it be that the seat is just off the track? And if so how can I fix it?
Old Mar 14, 2014 | 12:58 AM
The Mad Dooby's Avatar
Take the seat out and inspect it. you can take apart the tracks and rails underneath the seats pretty easily.
Old Mar 17, 2014 | 04:46 PM
hayman3347's Avatar
You remove the seat by 4 bolts mounting it to the floor. Then unplug the motors and look for crud and dirt and stuff on the seat frame. Clean it up and lube with WD-40 on the worm gears. This assumes it is not really off the tracks :-) I fixed mine by lubing only while the seat was still bolted down ( I could see the crud and rust with a flashlight).
Old Mar 20, 2014 | 08:46 AM
dilabop's Avatar
You might just have something stuck in the track
RRRoamer
Jan 19, 2017 05:27 PM
poldrv
Aug 18, 2015 06:42 AM
glo106
Aug 11, 2015 08:29 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
