dash lights
Old Apr 24, 2006 | 11:57 PM
2000gTstang's Avatar
my dash lights arent working after some work on the radio. ive checked the normal fuses and theyre all ok. any ideas - thanks
ps. just got the stang back from the dealership, she looks better than when i bought her
Old Apr 25, 2006 | 05:49 AM
mudshuvel319's Avatar
Did you do any wire cutting/splicing when you were doing the radio work. if you did, its possible that you may have exposed a bare wire and there's a short somewhere. or you could have cut or disconnected a wire somewhere in the area. the factory radio display dims when you turn the headlights on, as does the dash display. its possible that this common connection was damaged somewhere in the system. good luck, and hopefully someone can give you more specific help.
Old Apr 25, 2006 | 01:59 PM
TJ4Cam's Avatar
I agree, something must have happened while you were in there with the radio, I would pull it back out and recheck my work real quick, you say all fuses are good?
Old Apr 26, 2006 | 12:22 AM
i pulled the radio out and checked the wires. the aftermarket HU i have doesnt have a dimmer control, but the harness does. that was the wire that was bare and shorting out. i checked the fuses again and sure enough that one was blown. about a year back i posted asking about the electrical system in the car, how my dome, map, and vanity lights didnt work unless i pressed the disarm button on the keypad. i thought i checked all the fuses then. that was infact the first thing i did. well, in trying to fix the dash lights i replaced a blown fuse and it happened to fix my lights, today was the first day i could actually use my map lights how theyre ment to be used. duh..
Old Apr 26, 2006 | 04:31 AM
Glad I was able to be of some assistance. And now you have map lights!
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
