A couple random mod questions
Old Mar 13, 2005 | 05:53 PM
bucky's Avatar
I recently got the steeda cat back installed on my 01 auto gt. nice sound. when it was up on the lift and i was watching them put it in, i noticed the other part of the exhaust (with the cat converters) looked like poo. all rusty looking. what is the proper name for this piece LOL? and if I get it replaced, should i go with the steeda brand since that is what the cat back is on there now?
also, i have motive 3.90 gears, nice punch to the car when you want it. a friend recommended i look into some brakes, he said they are gonna wear out alot more quickly with that gear ratio.
thanks for your help.
Old Mar 13, 2005 | 07:37 PM
Evil_Capri's Avatar
The exhaust piece with the CATS is called a h-pipe (in aftermarket there are replacement h & x pipes). You do not have to replace with a Steeda unit, it just depends on preference, as well as (depending on area you live) installing a h/x pipes with or without CATS.
As far as brakes you could install better pads (hawk), but you brakes shoudn't wear out any faster . . . unless you are driving much faster and hence using more brakes.
Old Mar 17, 2005 | 08:57 PM
bucky's Avatar
thanks a bunch!!
Old Mar 18, 2005 | 08:38 PM
Fordracing200's Avatar
Yah, brakes wont wear out faster but better brakes are always great, 03 cobra units will be a great upgrade for your car and the pads and such are relatively cheap.
2012Kona
Aug 21, 2015 08:36 AM
tdf017
Aug 5, 2015 10:13 AM
db2797
Jul 28, 2015 07:34 PM
