Cobra Whinnying Noise
Old Mar 11, 2012 | 08:42 AM
Dbranham's Avatar
Here a video i took of it after i noticed the noise. Sorry for the bad filming. Its the whinnying you can hear after a little rev.
Old Mar 11, 2012 | 11:07 AM
Blue Notch's Avatar
Does it go away with your radio turned off? Mine whines like crazy through my speakers. I apparently have a loose ground somewhere.
Old Mar 11, 2012 | 11:49 AM
Onesickstang01's Avatar
Sounds like power steering or alternator. Check power sterring flui level
Old Mar 11, 2012 | 01:48 PM
mdelao's Avatar
Check if he noise increase when you push the brake until the end on Parking, if is do it is the brake booster, probably liquid level is low
Old Mar 11, 2012 | 02:22 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
That's on hydroboost vehicles. Not vacuum boost. Unless his cobra is hydroboosted.. I can't remember.
Old Mar 11, 2012 | 02:46 PM
Dbranham's Avatar
It does get louder when braking
Old Mar 11, 2012 | 02:50 PM
Dbranham's Avatar
I did notice it seems harder to steer too I'll check it out
Old Mar 11, 2012 | 03:35 PM
Bear Eats King...
Bear ****s Bone
You most likely have a hydro boost style brake system and your powersteering pump is going out causing you to hear it when you apply the brakes. You will need a new power steering pump most likely.
Old Mar 11, 2012 | 05:27 PM
Dbranham's Avatar
Oddly everything seems to be working just fine today!
Old Mar 12, 2012 | 10:24 AM
mdelao's Avatar
I had same issue, this came after repair a steering wheel leak. the mechanic said that it would be decreasing, so it did it but i can’t notice how harder was the noise before the steering wheels hose replacement
Old Mar 12, 2012 | 11:39 AM
Bear Eats King...
Bear ****s Bone
Steering wheel leak??? What's that??? Does it have to do with the blinker fluid tank?
Old Mar 12, 2012 | 12:20 PM
mdelao's Avatar
I was talking about a leak in to one of the hoses in the steering wheel system.
Old Mar 14, 2012 | 06:48 PM
White94GT's Avatar
Sounds like power steering pump!
Old Jun 27, 2012 | 10:09 PM
Dbranham's Avatar
Hate to be that guy that brings these oldish threads back.
But almost four months since I noticed this and finally got around to getting it fixed.
Power steering flush was all I needed.
Everything is running back to normal now.
Old Jun 28, 2012 | 08:46 AM
mdelao's Avatar
Is ok to woke up old threats, some times there are threads with Unsolved issues, good to know what fixes yours
Old Jun 30, 2012 | 10:15 AM
Bear Eats King...
Bear ****s Bone
Flushes tend to be a temporary fix because the old fluid already caused some damage. Most cases anyways. I would keep an eye out as you may still have an issue.
Old Jun 30, 2012 | 01:07 PM
Dbranham's Avatar
Will do. I hope it is fixed however.
Old Jul 3, 2012 | 12:22 PM
Chubbs88's Avatar
Sounds exactly the same as when one of my pulleys was bad (bad bearing)
Old Jul 8, 2012 | 03:38 AM
95_5.0's Avatar
Check the power steering. That sounds like the pump not getting enough or low on fluid
Old Aug 21, 2012 | 10:15 AM
Dbranham's Avatar
Once again tbone is right. The whining noise came back last night. It was a temporary fix. I haven't noticed any machincal problems with this other than the annoying whining noise
