Carb to throttle body?
Old Apr 13, 2011 | 08:48 PM
Weeman333's Avatar
Is it possible to convert a carb 302 to throttle body? I found a sweet motor , but idk if it will go in my 95 gt. Thank for the help
Old Apr 13, 2011 | 10:39 PM
houtex's Avatar
Yes, get this, or something like it:
http://www.holley.com/502-20S.asp
But I'm curious as to why you'd downgrade the '95 GT 5.0 FI engine to a 5.0 carb-to-TBFI setup... and whether it's legal except on the drag strip.
In which case, if you're draggin', then a big carb is a better idea anyway.
Old Apr 14, 2011 | 01:07 AM
Weeman333's Avatar
Thanks man.... I dropped an ext. And socket down my dist. Hole. I thought it went to the pan, but when I turned the starter..... Bam straight into the cam gear
Old Apr 14, 2011 | 04:22 AM
Weeman333's Avatar
Can I not just bolt my intake and throttle body onto the other motor? Some people say it'll work and some say it won't... The 86 has roller heads and less than 1000 miles since the rebuild.
Old Apr 14, 2011 | 09:27 PM
houtex's Avatar
Yeah, I was gonna say something about that too, but I didn't know where you were going with things... but I'm not expert enough on that swappage, 86 complete long block in a 95 FI setup.
Doing a little googling... seems like they should swap out, overall...
I would be concerned the cam profiles weren't the same, but they do have the same firing order... so if you put all the intake/injection stuff on it from the '95, it likely will fire up and figure itself out... maybe... I dunno.
From what I'm reading, the difference is the intake was lower and a couple of other minor things from the '93 to the '94-5 versions of those motors. That's pretty much it... from what I'm reading.
If it was me, I would have to *know* it'd work before I didn't just replace the cam gear or whole shaft on the '95 and be done with it. But yeah, it seems you could do it.
But I didn't say "yes", so it's your call.
Old Apr 18, 2011 | 03:55 AM
Weeman333's Avatar
Thanks man, your the ****, it's a beast motor. I really really think it'll bolt, and I've seen both motors. But thanks for all he help
Old Apr 18, 2011 | 09:51 PM
houtex's Avatar
I dunno if I helped all that much. Heh. Kinda want to be there to see it go down.
I'd be interested in what happened, good or bad, with this. Good luck and have fun with it!
Old Apr 25, 2011 | 03:14 AM
Weeman333's Avatar
Motor came out today. Now I'll put this to the test, I'ma try it tomorrow
kponypower
Jun 17, 2020 07:17 AM
GLOCKer
Sep 28, 2015 05:20 PM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
