Cant Shift
Cant Shift
OK, so I burned the clutch a bit yesterday because some jackass cut me off, and Then I couldn't shift into any gear, as I was rolling. I had to force it pretty hard, but no grinding or anything like that, and it went into gear and as I was driving home it felt fine again.
This morning I cant shift into any gear from parked with the engine on.
The clutch feels the same, theres no resistance/whine/grind.
I dont think it's the TO bearing, its more like the clutch operates, but the disc is stuck to the flywheel.
Steeda quadrant
And I just got it to work again :/
I started it, then put the shifter up against 4th, where it was grinding, it wound down on grinding, and then it went into 4th, and every other gear. How utterly bizzare. Thank god I'm getting a fat bonus soon, so I can buy a new tranny
Gigantor
5/11/23 07:31 PM
