Cant Shift
Old Sep 11, 2014 | 11:15 AM
Valnar300's Avatar
Cant Shift
OK, so I burned the clutch a bit yesterday because some jackass cut me off, and Then I couldn't shift into any gear, as I was rolling. I had to force it pretty hard, but no grinding or anything like that, and it went into gear and as I was driving home it felt fine again.
This morning I cant shift into any gear from parked with the engine on.
The clutch feels the same, theres no resistance/whine/grind.
I dont think it's the TO bearing, its more like the clutch operates, but the disc is stuck to the flywheel.
Old Sep 11, 2014 | 10:22 PM
Valnar300's Avatar
Steeda quadrant
And I just got it to work again :/
I started it, then put the shifter up against 4th, where it was grinding, it wound down on grinding, and then it went into 4th, and every other gear. How utterly bizzare. Thank god I'm getting a fat bonus soon, so I can buy a new tranny
Old Sep 24, 2014 | 11:41 PM
Valnar300's Avatar
That and a seized pilot bearing and grumbly TO bearing. I think it was the pilot that was causing the trand to not wind down until it was forced
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
