Bbk intake 78mm tb
Old Aug 14, 2011 | 12:45 PM
whouok's Avatar
Bbk intake 78mm tb
Put on and seems sluggish any info?
Old Aug 14, 2011 | 12:57 PM
Pinoy361's Avatar
Well what else do you have on the car?
Old Aug 14, 2011 | 03:49 PM
Onesickstang01's Avatar
Unless you are F/I its too big and will be sluggish
Old Aug 14, 2011 | 04:12 PM
cntchds's Avatar
it is a fairly low velocity intake, so it should be a little less peppy off the line, but should help it breathe above 3k or so.
Old Aug 14, 2011 | 04:15 PM
stork68's Avatar
I have same part on mine. Only thing I noticed was a little whistling when accelerating hard. Do you have a tuner?
Old Aug 14, 2011 | 04:22 PM
whouok's Avatar
Bbl headers h pipe jlc cold air no tuner yet is that the problem?
Old Aug 14, 2011 | 04:26 PM
stork68's Avatar
Not sure if that will help your problem, but you may benefit from getting a tuner either way.
Old Aug 14, 2011 | 04:27 PM
whouok's Avatar
And 3:55 wheels are front 18/9 rear are 18/10.5 gt 500 wheels
Old Aug 14, 2011 | 05:26 PM
whouok's Avatar
F/I ?
Old Aug 14, 2011 | 07:12 PM
cntchds's Avatar
Forced Induction ie a supercharger or turbo.
Old Aug 14, 2011 | 07:31 PM
whouok's Avatar
No it's not I just bought this car trying to figure it out. Thank You! I have the stock intake should I put it back on?
Old Aug 14, 2011 | 08:02 PM
cntchds's Avatar
It all depends on your plans. If that is your plans though, I'd be glad to take it off your hands.
Old Aug 14, 2011 | 09:15 PM
Pinoy361's Avatar
Yea forced induction should definitely be ur next step if u wanna get the full potential out of her
Old Aug 14, 2011 | 09:26 PM
mach 1000's Avatar
Did u chip it yet?
Old Aug 15, 2011 | 07:06 AM
whouok's Avatar
Not yet have been thinking about it would that help it? Never had a 4.6
Old Aug 15, 2011 | 07:57 AM
Termi2003's Avatar
Like All the other comments, 78mm is pretty big unless your car has a power adder. A tuner is pretty much a must...it will waken the car up pretty good with the supporting mods you have.
Old Aug 15, 2011 | 08:00 AM
whouok's Avatar
Thanks that will be next Thanks
Old Aug 20, 2011 | 09:11 AM
SVTCobraR315's Avatar
im planning on getting that 78mm. these 2v have no top end... we all know that. thats why i want it. i was thinking cams down the road too. but it all depends how you want to drive your pony.
Old Aug 24, 2011 | 09:47 AM
JScottGT's Avatar
78mm is a bit big for a mostly stock 4.6L. I've seen some test data and it really does not make much sense to go much bigger than 70mm. Now if you had ported heads, and a big set of cams, you would be able to take advantage of such a large TB. Also, like others have said, F/I would also benefit from a large TB as well.
Old Aug 25, 2011 | 11:45 AM
Slambanc's Avatar
Believe me when I tell you that installing a larger throttle body. You don't see a big jump on the horse power. I've installed over $6000.00 in upgrades on my 2003 GT 4.6 2v. My Dyno #'s are 270rwhp , and 312 torque. I was expecting at the least 300rwhp.
