Alignment
Old Mar 21, 2010 | 03:00 PM
stang23456's Avatar
Alignment
if your car is out of alignment, could it cause wheel shake/vibration ? My 04 GT is vibrating between 40-55 MPH and is pulling to the right. Ive had all tires road forced balanced and everything checked out suspension wise.
Old Mar 21, 2010 | 03:11 PM
yugoboss's Avatar
You probably have a tire thats starting to seperate, or is still out of balance, even a bent rim.
Old Mar 22, 2010 | 06:02 AM
JScottGT's Avatar
A bad tie-rod end would cause the issue you are describing. They are a pretty easy fix. You will still need an alignment after you do those.
Old Mar 22, 2010 | 01:42 PM
stang23456's Avatar
all suspension parts have been checked though, including tie rods
Old Mar 26, 2010 | 04:20 PM
cntchds's Avatar
Why haven't you just gotten an alignment? I would not think it could be specific to a speed range, but there is no reason not to get it done.
Old Mar 26, 2010 | 04:53 PM
yugoboss's Avatar
If your tires are wearing fine, and your steering wheel is straight, you don't need an alignment. If front end
checked out good you have a out of balance tire, bent rim, our a tire starting to seperate.
OneCoolGT
Dec 10, 2015 07:55 PM
dohc97
Sep 27, 2015 06:32 AM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 1, 2015 01:19 PM
