Adding oil
Old Jan 24, 2006 | 06:33 PM
MY05GT's Avatar
I have always taken my cars in to have any maintenance done....until I bought the Stangs ......now no one touches 'em. My question is, the 95 Cobra with 152,600 miles ( bought it at 150 and changed the oil 1st thing ) needed a quart, Is this something to be concerned about or is it normal for a high mileage car. None of my previous cars needed oil before the 3k change including a 91 Escort with 200k.
Old Jan 24, 2006 | 07:29 PM
Valentino's Avatar
In theory if you have to add oil between regular changes its leaking somewhere or burning, although its not uncommon to need to add oil in a high-mileage engine.
Old Jan 25, 2006 | 01:20 AM
jgsmuzzy's Avatar
High mileage engines use oil. As the engine ages, the pistons and rings can start to go "elliptical", i.e. slightly oval with wear, a little oil gets past this minute gap and burns with the petrol. I do not think it is anything major, just as long as you are not driving down the road trailing smoke. An engine rebuild would sort it as the pistons and rings would probably get changed
Old Jan 25, 2006 | 03:43 PM
1995gtbbk's Avatar
i have a 95 gt and it uses very little oil w/ 135k miles but my friends 04 gt burns almost 3/4 quarts of oil by the time of the next oil change, both stangs run beautifully, they just happen to use oil, quite normal
Old Jan 25, 2006 | 04:36 PM
MY05GT's Avatar
Great....Thanks for the help. It may not have actually gone through a whole quart as it was at the low end of normal at the oil change and is now at the high end after adding a quart (It had gone below normal before I added, but just barely) .
Old Jan 26, 2006 | 03:54 PM
FastCobraBOYEEEE's Avatar
Saturns burn oil because of the engine design...
Old Jan 28, 2006 | 12:33 AM
joker's Avatar
If you only burn a quarts every 3k miles, then you have a perfectly normal used 302.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
