97 cobra stalling need help
Old Sep 14, 2011 | 09:21 PM
bs13855's Avatar
I'll describe it the best I can.
Since
Problem
I've changed coils, plugs, wires,oil,oil filter, fuel filter, cleaned air filter and deleted the imrc's.
Problem
When it's hot and muggy out the problem occurs more often. When I'm driving on the highway the cobra will just stall. I'll pull over crank the motor over it will take a couple seconds and starts right up. During this period I can smell alot of gas but the cobra will drive fine and the gas smell will go away.
I'm leaning towards a tsp problem, or cps problem or dirty throttle body
Any advice
Old Sep 14, 2011 | 09:43 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
How many miles? Cel on?
Old Sep 14, 2011 | 10:11 PM
bs13855's Avatar
About 60,000 since the rebuild 150,000 body
bs13855's Avatar
What's CEL on?
Old Sep 14, 2011 | 10:23 PM
Planeswalker's Avatar
Originally Posted by bs13855
What's CEL on?
Check Engine Light
Can go by Autozone and have it read, or if you have a tuner you can use it.
Old Sep 14, 2011 | 10:46 PM
bs13855's Avatar
Negative on it coming on. However once it did and I had it towed to a mustang shop and it read 2 codes
1) the code for a open fuel cap
2) misfire
I bought a new fuel cap we reset the computer it drove fine then It did the stall thing again. It's very inconsistent and happens most the time on hot and humid days.
I live in south fl
Old Sep 14, 2011 | 10:49 PM
bs13855's Avatar
It has done the stalling issue probably 30 times in the last year and only once I got the CEL
Old Sep 15, 2011 | 02:00 AM
Autotooner's Avatar
My C/T is cooler than Arin is.
hmm, tps sounds possible. does it seem to bog down when it stalls?
Old Sep 15, 2011 | 06:20 AM
Bear Eats King...
Bear ****s Bone
Maybe egr is getting stuck open.
What exactly does it do when it dies. Is it a quick death?
Old Sep 15, 2011 | 09:10 AM
bs13855's Avatar
It gets real sluggish. Maybe like too much fuel not enough air then gets real low in rpms and then it stalls
Old Sep 15, 2011 | 10:01 AM
Bear Eats King...
Bear ****s Bone
Ccrm might be kicking the fuel pump off and keeping it off. Tough one.
Old Sep 15, 2011 | 12:16 PM
bs13855's Avatar
What's ccrm
Old Sep 15, 2011 | 12:18 PM
Bear Eats King...
Bear ****s Bone
What's ccrm
Constant control relay module.
Old Sep 15, 2011 | 02:37 PM
bs13855's Avatar
Ok well thank you I'll see about changing that, the tps, cps and can I take my throttle body and clean it if so any tips
Old Sep 15, 2011 | 02:39 PM
bs13855's Avatar
This is my baby by the way
Old Sep 15, 2011 | 02:47 PM
Bear Eats King...
Bear ****s Bone
These are not bad about throttle bodies. But you can. Just locate a gasket first. They are hard to find. Nice car by the way.
Here is my 97
Old Sep 18, 2011 | 12:13 PM
bs13855's Avatar
Fixxxxxxxxed I used mas air sensor cleaner on my mafs and it seems to be allot better
Old Sep 18, 2011 | 12:19 PM
Bear Eats King...
Bear ****s Bone
Glad to hear
Old Sep 18, 2011 | 05:27 PM
br23will's Avatar
Just a thought. I know a lot of the ford trucks have this issue. They have a faulty inertia switch. It will shut off the fuel and kill the engine. Not sure if mustangs have one but it might be worth checking
Old Sep 18, 2011 | 05:30 PM
Bear Eats King...
Bear ****s Bone
Mustangs do have one. In his its in the trunk. Driver side.
