95 gt surging problem
Old Oct 9, 2011 | 09:24 PM
95gtchick's Avatar
Ok so i have a 95 ft, it has a idle and surging problem. When you start the car it shakes pretty bad. Then will smooth out, but the idle starts to go from 500-1000rpms goes up and down constantly. (Hunting idle) then smooths out when you start to drive it. But shortly after that it will start to surge in 4th and 5th gear. Like it lost power or fuel, for a second. Any ideas?
Old Oct 9, 2011 | 10:42 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Sounds like the tps needs to be reset. Not positive though
Old Oct 10, 2011 | 07:55 AM
fuel filter and clean the throttle body..... Oh and welcome to TMS.
Old Oct 17, 2011 | 11:49 PM
Haulin Twinz08's Avatar
Try the idle air control valve. Mine was doing the same tool I replaced it
Old Oct 18, 2011 | 08:16 PM
1998ponypower's Avatar
it may need tuned, my 98GT is doing the same thing and in the end I put it on a Dyno and it is running much better now. I would check the IAC first and also the ITC sensor.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
samjluck
Sep 17, 2015 10:24 PM
