93 octane
Old Mar 4, 2012 | 08:59 PM
br23will's Avatar
93 octane
Does anyone have problems running 93 octane in their car. I get an occasional long crank. Only when running 93 as opposed to 87
Old Mar 4, 2012 | 09:02 PM
11SHELBYGT500's Avatar
What's 93 octane?
Old Mar 4, 2012 | 09:14 PM
br23will's Avatar
Fuel. I hope you're running in a GT500
Old Mar 4, 2012 | 09:26 PM
We don't have that here.
Old Mar 4, 2012 | 09:57 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
I run it in my cobra. But I also have an 11 to 1 compression ratio and 87 causes detonation in my car. So I need the 93. No long cranks for me
Old Mar 5, 2012 | 11:13 AM
br23will's Avatar
I'm thinking about putting in an iridium plug. Opposed to the platinum motorcraft
Old Mar 5, 2012 | 01:32 PM
01GT's Avatar
I have denso iridium in my 01gt. I love them.
Old Mar 5, 2012 | 03:48 PM
br23will's Avatar
I'm thinking ngk iridium ix. Any thoughts?
Old Mar 5, 2012 | 04:37 PM
cpotts13's Avatar
Let me be the one to ask the dumb question... do you have a 93 octane tune??
Old Mar 5, 2012 | 05:11 PM
Bear Eats King...
Bear ****s Bone
91 and 93 octane tunes are almost identical. So I just run a 91 tune. We only have 93 octane stations. No 91.
Old Mar 5, 2012 | 05:20 PM
cpotts13's Avatar
Yeah, 93 is closer to 91 in actuality.
Old Mar 5, 2012 | 05:55 PM
its a waste to run the 93 in a more or less stock 99-04 gt. I would think the long would crank would have nothing to do with the 93 oct. Does it only do it after you run it for a while or all the time? Like from a cold start up
Old Mar 5, 2012 | 08:08 PM
br23will's Avatar
I do have it tuned for 93. The long crank happens at random. Does not matter hot or cold. The only thing I can figure is the fuel. It never did it with 87 octane
Old Apr 4, 2012 | 09:03 PM
shaunrc's Avatar
Texas bone king is running 11.1 compression ratio that is why he doesn't hear that the only time you run premium fuel is either OE specs or you raise the compression ratio
Old Apr 6, 2012 | 08:56 PM
Knight's Avatar
Needs to be more Astony
don't run 93 in a stock 04 gt engine unless you have it tuned for it. Just wasting money on the extra octane if your timing isn't bumped to take advantage of it.
Also forget the ix plugs the normal NGKs will work fine and are much cheaper and most of the time are less finicky about gap size.
Old Apr 6, 2012 | 09:04 PM
01GT's Avatar
I run denso iridium. Denso has the worlds smallest tip. And has the most iridium. Definatley noticed a difference on a smother throttle at upper rpm range.
Cdvision
Sep 5, 2015 05:22 PM
jim010
Aug 13, 2015 02:32 PM
