5th gear grind
Old May 29, 2012 | 10:28 PM
SuperSix's Avatar
5th gear grind
I just got a GT after totaling my v6. Its awesome but i have been having an increasing amount of grind from 4th to 5th and its getting harder to get it into reverse. The clutch is a little burnt but i have no problems up until 5th gear. Do i need a new clutch or am i looking at a syncro problem?
Old May 30, 2012 | 05:50 AM
Dbranham's Avatar
When it's in 5th and you floor it do the rpms rise too fast, as if not in gear almost?
I heard when a clutch is about to go you notice it more in the higher gears.
Old May 30, 2012 | 06:25 AM
AlsCobra's Avatar
A Man Just Needs Some....
Could be a synchro/blocker ring problem. If your clutch is worn, clutch it first and go from there.
Rando
Aug 25, 2021 11:12 AM
Sep 30, 2015 07:02 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
