2004 Catback and Midpipe
Old Feb 10, 2013 | 10:50 PM
2004GTMidnight's Avatar
So do I really have to cut my factory exhaust to be able to remove these from the car.? I would really like a way to quickly remove these without cutting them so I always have the stock parts in my garage.
Old Feb 14, 2013 | 09:54 AM
benjyc32's Avatar
It should not need to be cut at all. not unless the bolts are seized from rust. If you look under your car the mid pipe (H pipe) and your tailpipe (right before the mufflers begin) are held by two bolts and nuts on each pipe. if you loosen those and drop the tailpipe hangers the mufflers should come out (If you can get your car high enough off the ground) and the midpipes you just disconnect and let them come down. that part doesnt matter how high it is off the ground. But you should be able to get the tailpipes down if you can get your car in the air a bit to turn the pipes around the axel.
Airborne42
Sep 24, 2015 11:01 AM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
VinnyD
Sep 18, 2015 01:19 PM
Grabber5.00
Sep 13, 2015 06:53 AM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
