2000 Gt starting problem
Old Sep 9, 2012 | 07:39 PM
cpotts13's Avatar
Alright guys this one is a big ut oh...
PROBLEM
- Car will not crank, all the electronics work
So today i went to my local Firestone to get my alignment done, the guy that did it was a factory trained ford mechanic. So i asked him about the third starter bolt, he took a look at it and removed it free of charge in like 1 minute. Being that that one bolt was the only thing stopping me from swapping motor mounts, i was excited. Get home and pull it onto the ramps to get started. first off i removed the starter, then removed all the nuts and bolts from the passenger side motor mount, sweet. moved to the driver side got all the bolts off except ONE. the bottom bolt by the oil filter that has the red and black wire grounded to it wouldn't budge.. it seemed like the wires fused to the underside of the bolt.. so every time i loosened the bolt it would twist the wire.. okay well crap. after a good hour trying to get it to budge i determined if i continued i would cause more damage then I would fix. TIME TO REASSEMBLE. Defeated as i was all the bolts and hard ware to the old motor mounts went back together fine. When it came down to the starter i had an issue... It seems that the last person to take the starter off threaded the bolts wrong, which stripped the threads on the transmission housing where the starter mounts @!$&^*^%@(#, But i managed it get it threaded enough and the other bolt threaded fine, i left the top bolt off for obvious reasons... Re attached the two wires to the starter, plugged the battery up and BAM car wont start, wont even crank... wtf.
SYMTOMS
-Fuel pump primes
-PATS system disarms
-all electronics work
-fuses arent blown (to the best of my knowledge)
-Fuel cutoff switch hasnt been thrown
Any ideas or suggestions. I do not think those wires that kinda got mangled on the driverside motor mount bolt mentioned above would cause it to not start..
My theory is something over by the starter is not right.. But what could it be? the two red wires are secured.. is there any sort of grounding wire that attached to the motor mount bolt above it? I will mess with it tomorrow when i am not pissed at it...
Suggestions welcomed..
Old Sep 9, 2012 | 11:14 PM
JDF's Avatar
JDF
Look at your battery wires. Same thing happened to me and it ended up being that it wasn't grounded properly. I had a whopping 3 copper strands and some corrosion on my negative cable. It gave the one loud click whenever I tried starting it.
Old Sep 10, 2012 | 05:16 AM
cpotts13's Avatar
Hmmm last night a actually adjusted the negative cables it the strap that goes on the battery. And the strap itself is a few months old..
Old Sep 10, 2012 | 10:38 AM
shurtual86's Avatar
Are you stepping on the clutch? Just kidding. That is strange, from the video, it doesn't even make a sound when you try to start it.
Old Sep 10, 2012 | 12:31 PM
Getportfolio's Avatar
Not even a buzz at crank. Check those wires again.
Old Sep 10, 2012 | 01:01 PM
1slow03's Avatar
Yeach check those wires again. The ones you mangled go from the engine to the battery.
Old Sep 10, 2012 | 01:56 PM
cpotts13's Avatar
This is what i got.... skip to 20 seconds..
Old Sep 10, 2012 | 03:40 PM
cpotts13's Avatar
Fixed it guys! thanks for all the help. It turned out to be a loose wire to the starter. gave it a few taps with the hammer for extra luck. fired right up.
Old Sep 10, 2012 | 04:00 PM
shurtual86's Avatar
Old Sep 10, 2012 | 04:03 PM
Good news!
Old Sep 10, 2012 | 04:23 PM
cpotts13's Avatar
Yep. Probably the best feeling ever!
Mpaps
Oct 11, 2017 08:06 PM
