2000 Gt
Old Aug 5, 2013 | 11:53 PM
cpeery's Avatar
2000 Gt
Hello everyone this is my first mustang I have had it for about a month I've replaced the basics, timing belt, spark plugs , wires.all I know from what the guy told me he did is put a short shift in it which leads me to my first of three questions.1. I've noticed when im shifting in neutral or turning it sounds like the whole transmission is going to fall apart, like a rattle sound almost only when in neutral and turning feels fine shifting first sometimes I have to fight but normal shifting ok.2 went to replace the alternator today and the one I bought from AutoZone did not fit it was a inch to big, so I am forced to have to go to Ford for this I'm curious why it didn't fit it was the right replacement we double checked twice but it was not the size of the one I pulled out which is factory, and third I have a high squeak coming from the right front tire thought it was the hub bearing replaced it it is still there not ask the time but in and out from time to time like a high pitch squeak any comments would be appreciated Ty
Old Aug 12, 2013 | 10:26 AM
td01gt's Avatar
On the tranny check the tranny mounts. and check the shifter, to see if it was installed correctly.on your squeaky noise, check the brakes, and the strut mounts, also spring insulator. hope that helped.other member maybe able to give more info, direction.
00StangVert
1994-2004 V-6
Sep 11, 2015 12:08 PM
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
Stephanie Blaker
Aug 25, 2015 07:36 PM
