1994 Gt Suggestions
Old Feb 11, 2005 | 03:17 AM
cyberwolf1986's Avatar
Hi guys, i have a 1994 gt with 59,*** miles on it. I wanted to konw how would i get this car to run in the mid 13's without using cam, heads, or nitrous. i want to go with a supercharger setup, but i dont no which to use, or wat i need to add so it would let my car run in a way where nothin can mess up. I dont care what it's gona cost, but i would like it to be not that expensive. The car is a convertible 5.0 with a automatic transsmisson. thanx guys
Old Feb 11, 2005 | 11:17 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
A vortech kit is going to be your cheapest/best bet to get into the mid 13's. Push it about 8psi and it should do well for you.
Your best bet is to talk to some local shops in your area and see what they would recommend because a s/c is defintely going to require a good tune.
Old Feb 11, 2005 | 01:06 PM
Fordracing200's Avatar
I like the Procharger P-1SC kit. My uncle has it on his F-150 and it Cranks out some power. His truk will run up to the 128mph shut off point in 3rd gear. (automatic while being held, with shift kit)
Do you wanna keep the auto? If so put a C-4 in it with a 2800 stall converter, if you want the stick, go with a Temec T-56. also, a set of 4.10 gears will be great and pick up a few tenths for your car.
Old Feb 12, 2005 | 02:39 AM
Could my engine handle a supercharger, don't want anythin to go wrong with the engine becuase its been my moms car since 1994 and she gave it to me for my bday
Old Feb 12, 2005 | 12:08 PM
Blower will be fine as long as you keep the boost at a reasonable rate, like 9psi. Maintain a safe air/fuel ratio and timing.
Old Feb 13, 2005 | 06:04 PM
Mestizo's Avatar
I heard superchargers snap a lot of belts.....how does the Vortech and Procharger hold-up under regular use......kinda hard to define "regular use" with a supercharger.
Basically meaning not racing it every 10 secs, but when you need it.
Old Feb 14, 2005 | 01:23 PM
My uncle races his F-150 constantly against anything and everything and belt is fine, just make sure the pulleys are aligned correctly, otherwise the belt will get eaten up or jump off.
He even raced a Viper the other day and he got left when they hit 100, but had himt ill then.
Old Feb 20, 2005 | 02:34 PM
fiveopowered's Avatar
What's wrong with a cam, they will give you great power and an awsome sound! All the bolt on you can put on the better. A full exhaust, gears, chip and a full intake will cost around $3000, major difference in power.
Old Feb 21, 2005 | 08:47 AM
dfhurleydude182's Avatar
Yeah thats the good thing about 5.0's. They have tons of parts and they're really cheap. If It were my car, I would push a lot of NA power and if you run out of ideas, then I'd put a supercharger on. With a 5.0 I would go with full exhaust, cai, 75mm tb, pulleys, gt-40 heads, new cam, and a good tune and you can get it close to 300 to the rear wheels. With that much power, some good tires and suspension. You should easily be about low 13's.
Old Feb 21, 2005 | 03:17 PM
I would do cams and heads, but u don't know anything about them or what they would do to the car. I read about intake manifold and i was wondering how they perform in a basicly stock car
sorry i mean i dont no anythin bout them
Old Feb 21, 2005 | 03:29 PM
BullittMustang50's Avatar
I'd Go with a Supercharger, Vortech.. With the Right Parts and Time, you could easily get that car, where you want it
Old Feb 21, 2005 | 05:01 PM
cam, gears, slicks, exhaust, Turbo, TB, MAF, injectors, heads, rods, overbore to a 306, skinnies, intake, Tremec T-56
There is a list for you, a cam will add some good power to a 5.0 why dont u want one? the Heads will too, but that is an option, i listed it because they add alot of power and reduce weight.
Old Feb 22, 2005 | 10:55 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
That is alot more money, time and mods than the origional poster wants. A mid-low 13 sec car doesnt need half of that including the turbo, t-56, 306.
Old Feb 22, 2005 | 08:31 PM
I think i went a little overbored, but i think with a 306 the car would hit 13s.
Old Feb 23, 2005 | 09:24 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
overboard.
Anyways, if he's not wanting to pull the heads/intake, why would he want to pull the whole motor for a rebuild. A supercharger is going to be the quickest, most user friendly mod as long as he gets a good shop to tune the car properly.
Old Feb 23, 2005 | 11:13 AM
UA2k1GT's Avatar
not sure why you wouldn't want to do h/c/i, especially if worried about hurting the motor, BUT since you don't want to do that stuff, yeah a s/c will get you there.
but you can also look at other methods of improving times like others have said, such as gears, sticky tires, weight reduction, a drag suspension setup, things like that.
Old Feb 23, 2005 | 11:37 AM
Originally posted by Scothew+February 23, 2005, 10:27 AM--><div class='quotetop'>QUOTE(Scothew @ February 23, 2005, 10:27 AM)</div><div class='quotemain'><!--QuoteBegin-Fordracing200@February 22, 2005, 9:34 PM
overboard.
[/b][/quote]
Overbored, it was a joke......obviously a bad one
I didnt realize the H/I thing required less work than a 306. WHoops, i wasnt thinking strait.
Old Feb 23, 2005 | 12:11 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
well either one is going to be alot of work.. but to do a 306, you will have to pull the whole motor, not just the top end. Plus takeing it to a machine shop and reassembly.
Old Feb 23, 2005 | 01:53 PM
Yah, understood. The hairdryer is prolly the most reliable cheapest way to go. A single T-67 turbo with 10psi will produce some crazy power. Check this out www.hellionpowersystems.com
