02 GT Wheel Clicking Help
Old Apr 21, 2010 | 05:22 PM
InsidiousGT's Avatar
I have an '02 GT with 32k on it. Not many miles, but some of that is track time.
Anyway, recently I started hearing a ticking coming from the front left wheel well. Some info...
- it only ticks once its up to temp (after driving for a while)
- I tried rotating the tires (left rear up to left front and vice versa) and the front left still ticks, so its probably not the tireor wheel weight.
- one day when it started clicking I jacked it up and spun the tire manually.... and no click. so it only clicks with weight on it.
- when I jacked it up I felt for wiggle in the bearing and it felt pretty solid.
- once it starts clicking, it just keeps clicking no matter the conditions (smooth pavement or rough pavement, turning or going straight, slow or fast)
Anyone have any ideas what that might be?
Old Apr 21, 2010 | 06:26 PM
bluethunderhorse's Avatar
Check the bearing again sometimes they will be bad with no signs until they finally just fall apart
Old Apr 21, 2010 | 09:50 PM
ford4v429's Avatar
legacy Tms Member
know you swapped tires, but sometimes sounds are decieving...you certain theres not just a rock stuck in the tread, or maybe a nail/screw in a tire? Ive had all the above...back when our driveway was gravel the goodyears on our old galaxie were like gravel magnets
Old Apr 22, 2010 | 02:04 AM
cntchds's Avatar
Is the sound speed dependent? If it is I would look more into the rotating parts. If it's not I'd look at the non spinning parts. First thing that came to my mind was ball joint, but I have no idea what sound a bad ball joint makes before its last hoorah.
Old Apr 22, 2010 | 06:08 PM
Balljoints make a loud creaking sound and pop and crack they don't click
dontOverSteer
Aug 11, 2015 05:28 PM
05PRMTX
Aug 10, 2015 06:38 AM
Autogeek.net
Aug 5, 2015 05:13 PM
Jul 20, 2015 06:26 AM
dohc97
Jul 18, 2015 03:01 AM
