'01 suspension into 95 GT ?
I just bought a wrecked/stripped 2001 Bullit Mustang for parts. I was planning to put the front suspension, rearend, and brakes into a 1995 GT convertible. First I was told it all swapped... then I was told front suspension would not. A assumed (
) that since the 95 - '04 are lumped together that everything would swap. I know I can swap the rear end and all of the brakes... and most likely the rear springs... Just not sure about the front end. Any advice is appreciated. Thanks!
I'm not 100% sure, but the 95 still had the 5.0 and the 01 would have the 4.6. there is a good possibility that the K member and all attached goodies may have changed (including A-arms that the springs sit on)?? I don't know for sure. There were also changes due to government requirements made, but I'm again not 100% sure. Get them both jacked up and try to verify that the parts are common.
Everything will swap including the control arms except the K-member since the bullit had the 4.6, the engine mounting location is different.
99-04 mustangs the front control arms are a little longer than the 94-98 so the tires might stick out a little more
Thanks for the feedback. Engine is long gone... I just bought the rolling chassis. Previous owner stripped everything but what I wanted.
I've heard the control arm swap is an improvement. Thanks for the feedback
Evil_Capri
Sep 11, 2015 08:39 AM
