What center caps fit the Tri-Bar Three Spoke Wheels
Old Feb 20, 2015 | 12:21 PM
randyre's Avatar
I posted in the Wanted section, but this is more a technical question. What center caps fit this wheel? Anyone have a part number? Very hard to tell what might fit, also seems the center comes in a chrome version too. Will that fit? I'm going to paint the wheels anyhow.
Old Feb 21, 2015 | 11:07 PM
randyre's Avatar
Nobody knows? Anyone have this wheel and willing to get me the part number from the back of the center cap? I'm not near the car for another two weeks or I could do it myself.
Randy
Old Feb 22, 2015 | 08:20 AM
GottaHaveIt's Avatar
Do you have a picture of the wheel ?
Old Feb 23, 2015 | 02:07 PM
akdoggie's Avatar
Can you repost your picture? Randy, your picture didn't come thru. I have a bunch of wheel caps, but without a pic of the wheel, can't help you out.
Old Feb 23, 2015 | 02:14 PM
akdoggie's Avatar
Is this the wheel you are describing? If so, then most Ford wheels, 1998-04 will fit. The Taurus SHO, TBird, and etc, all use these covers. You can take the Tbird ones, and remove the emblem and make it smooth for painting. Hope that helps you some. There are two or three sizes of caps, but they usually, most will interchange. Good luck.
Old Feb 23, 2015 | 02:23 PM
randyre's Avatar
Nope, but close. Its the one with the teardrop shaped holes. I reposted the picture. I believe the center-cap is flat and all those other ones are domed a little.
Old Feb 23, 2015 | 06:51 PM
my son has 6 of those we'd just found 2 at a wrecker for like 5.00 each now he has 6
Old Feb 23, 2015 | 07:05 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
These wheels?
Old Feb 23, 2015 | 07:39 PM
randyre's Avatar
These wheels?
YES!
Old Feb 23, 2015 | 07:54 PM
Like Father...
I ♥ Sausage
YES!
Late Model Restoration usually has quite a bit of stuff like that, but it would probably be high. Might be cheaper just to buy a set of OEM GT wheels and caps from that era that you like on fleabay or a junkyard.
Old Feb 23, 2015 | 08:02 PM
Like Father...
I ♥ Sausage
You might give these guys a call and see what they have laying around. They're in Ga. and they've usually got a little bit of everything. Good folks to do business with.
http://mpsautosalvage.com/sunshop/
Old Feb 23, 2015 | 08:17 PM
Getportfolio's Avatar
http://www.truckinnovations.com Try this part number: f4zc1a096cb
Old Feb 24, 2015 | 10:44 AM
randyre's Avatar
Thanks, that helped. I got one on the way, hope it matches, if not I'll take AK's advice and just buy any 6.5" center that I like in a set of four.
Diode Dynamics
Jun 12, 2018 03:26 PM
Jul 17, 2015 05:40 PM
