What center caps fit the Tri-Bar Three Spoke Wheels
I posted in the Wanted section, but this is more a technical question. What center caps fit this wheel? Anyone have a part number? Very hard to tell what might fit, also seems the center comes in a chrome version too. Will that fit? I'm going to paint the wheels anyhow.
https://dl-web.dropbox.com/get/Publi...IwrZITe6-Lm2dw |
Nobody knows? Anyone have this wheel and willing to get me the part number from the back of the center cap? I'm not near the car for another two weeks or I could do it myself.
Thanks Randy |
Do you have a picture of the wheel ?
Can you repost your picture? Randy, your picture didn't come thru. I have a bunch of wheel caps, but without a pic of the wheel, can't help you out.
1 Attachment(s)
Is this the wheel you are describing? If so, then most Ford wheels, 1998-04 will fit. The Taurus SHO, TBird, and etc, all use these covers. You can take the Tbird ones, and remove the emblem and make it smooth for painting. Hope that helps you some. There are two or three sizes of caps, but they usually, most will interchange. Good luck.
Nope, but close. Its the one with the teardrop shaped holes. I reposted the picture. I believe the center-cap is flat and all those other ones are domed a little.
my son has 6 of those we'd just found 2 at a wrecker for like 5.00 each now he has 6
Originally Posted by randyre
(Post 6901451)
These wheels? http://mustangattitude.com/mustang/1...6_00027_09.jpg |
(Post 6901552)
YES! |
(Post 6901567)
YES!
You might give these guys a call and see what they have laying around. They're in Ga. and they've usually got a little bit of everything. Good folks to do business with.
http://mpsautosalvage.com/sunshop/ |
http://www.truckinnovations.com Try this part number: f4zc1a096cb
(Post 6901579)
Thanks, that helped. I got one on the way, hope it matches, if not I'll take AK's advice and just buy any 6.5" center that I like in a set of four. |
