Twin turbo questions
Old Jun 8, 2012 | 05:31 PM
deadjay82's Avatar
Ok, I have an 01 V6 that I am going to put a twin turbo set up on. I am thinking 40mm to 80mm turbos in a sequential set up, but don't know what size fuel rails, injectors, and fuel pump I wanna go with. I also wanna change the cam, but not sure what I wanna do with that yet either. I will be putting 3.73 gears and possibly changing the tranny as well. Let me know what ya think and please, any advice will help. Thanks
Old Feb 21, 2013 | 04:36 PM
TheMuffinMan's Avatar
You'll need more than just a tranny. You'll have to put forged internals into it or your just going to blow up your engine from the twins.
Old Feb 21, 2013 | 06:14 PM
Blackout's Avatar
Why would you need to swap the trany
Old Feb 21, 2013 | 07:47 PM
I don't think the stock tranny can handle it depending on how much power you make. I might be wrong but I think it can only handle around 400 an with twin turbo you can easily make more than that
Old Feb 21, 2013 | 07:51 PM
Blackout's Avatar
I plan on 400hp
Old Feb 21, 2013 | 07:52 PM
Blackout's Avatar
And yes I know the muffin man
Old Feb 21, 2013 | 07:56 PM
SilverSkoundrel's Avatar
The muffin top man
Old Feb 21, 2013 | 08:06 PM
I plan on 400hp
You should be ok then but it wouldn't hurt to at least beef up the parts of the tranny. I think the auto is the same in the v6 as the GT, if so it should be fine at 400. He manual should be fine too but a better clutch couldn't hurt.
Old Feb 22, 2013 | 09:09 AM
Blackout's Avatar
Yeah I looked it up
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
