T-5 swap.
Old Feb 20, 2013 | 08:31 PM
Blackout's Avatar
T-5 swap.
Is there any place where I can go and get rid of my automatic transmission and get a standard in my car?
Old Feb 20, 2013 | 09:39 PM
shurtual86's Avatar
Junkyard do you mean trade it in for a t-5 manual tranny
Old Feb 20, 2013 | 09:59 PM
Blackout's Avatar
Yeah
Old Feb 21, 2013 | 05:55 AM
1999Pony's Avatar
Its very possible. You need a pedal assembly, tranny, clutch, flywheel, clutch cable, shifter and possibly a driveshaft (I can't remember off the top of my head at the moment). You will probably also need to cut a hole for the shifter(or enlarge the current one). Junkyard is the best place if you can find a 5speed so you can pull what you need. Although I would get a new clutch and flywheel at the same time.
Old Feb 21, 2013 | 11:18 AM
Blackout's Avatar
Wonder if I could go swap mine for the standard where I got my transmission in the first place
Old Feb 21, 2013 | 11:26 AM
Blackout's Avatar
I'm going to buy these parts. Like new. What year should I ask for?
They ask for year, model, make?
That was for a v6 right? The t5
Old Feb 21, 2013 | 03:47 PM
1999Pony's Avatar
Just ask for whatever year yours is. And yes v6s came with them.
Old Feb 21, 2013 | 06:15 PM
Blackout's Avatar
A guy to me it's not worth it to swap. Lots of trouble....
Blackout's Avatar
The not so good mechanic guy anyways
Old Feb 21, 2013 | 06:16 PM
Blackout's Avatar
Not that I would let him do the install since I do all my work I just wanted to check before I set my mind on it
Old Feb 21, 2013 | 09:01 PM
1999Pony's Avatar
Its all about what you want. Its not exactly quick and easy, but if you want a 5 speed, its your car and you should build it to your enjoyment.
Old Feb 21, 2013 | 09:14 PM
Blackout's Avatar
How do you connect the clutch assembly to the car?
Old Feb 21, 2013 | 09:18 PM
bluethunderhorse's Avatar
You will need a flywheel, bell housing, driveshaft, trans crossmember, clutch, pressure plate, pilot bearing, throwout bearing, pedals, clutch cable, clutch fork, clutch fork pivot ball, cable quadrant, speed sensor from a 99 five speed car, and lots of tylenol or advil
Old Feb 22, 2013 | 09:08 AM
Blackout's Avatar
Hmm not worth it.
Blackout's Avatar
I could buy a shift kit and have less headache
Old Feb 22, 2013 | 09:27 AM
1999Pony's Avatar
True that.
Old Feb 22, 2013 | 11:15 AM
Blackout's Avatar
For real true that
5.8KB
Sep 10, 2015 07:00 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
Billybix76
V6 Performance Mods
Oct 16, 2007 08:38 PM
Mberglo
Rocket City Mustang Club
Mar 1, 2007 06:25 PM
MY05GT
1994-2004 V-8
Sep 8, 2006 07:46 AM
