Trouble shooting
Old Jun 25, 2015 | 05:27 PM
Daniel harte's Avatar
Trouble shooting
My 2000 mustang (5 speed manual) has this very confusing issue and I need help. When it is fully warmed up and its a relatively hot day outside my car does this thing where if I give it medium to hard throttle it'll stop accelerating at like 2500 rmp and start bogging and slowing down (the more throttle the more it slows down) so i have to accelrate very slowly in order to move foward. Eventually it'll get to the point where I can't get it moving forward in first gear. When I shut off the engine there is this indescribable horrible smell from inside my car that I can't seem to trace to anything. It's almost like a sweet mettalic smell but it is terrible. I have no engine lights or pending codes and I've cleaned and checked the MAF and IAT sensors and they seem to be fine.
Old Jun 25, 2015 | 05:43 PM
Try the other standard running trouble items, fuel filter change, run a bottle or two of fuel filter cleaner through, change the spark plugs, etc.
Old Jun 25, 2015 | 06:23 PM
It's got a new fuel filter in it and I've ran sea foam in it and it still acts up.
Old Jun 26, 2015 | 09:55 AM
Jim74656's Avatar
has any thing else been done to the car in question? tune up, oil change, ect? has the car sat for a long period of time at any time? are there any odd noises coming from the car as your driving, idleing, or shifting?
Old Jun 26, 2015 | 10:01 AM
09-gt/cs's Avatar
May want to take a look at your cats if they are starting to get plugged up it will bog and the PCM goes into failsafe mode causing horrible acceleration.(although that should at least have a pending code associated) unless its the beginning stages. Cats that get extremely hot (from being clogged) can cause smells like you described and being an older car It probably has a little road grime and or stray fluids underneath anything could be burning off causing that smell.
Old Jun 26, 2015 | 10:05 AM
Jazzman442's Avatar
Do you have an OBD reader? Look at the live data and see if it is Fulal or air causing this.
Old Jun 26, 2015 | 10:11 AM
No recent tune-ups but I put oil in it recently and its a daily driver and no odd noises until it starts acting up. There's a clunky back-fire type of noise when it happens
Old Jun 26, 2015 | 10:16 AM
Tested my cats with an OBD 2 reader and they were fine. My friend suggested it might be an 02 sensor when it goes into open loop and that its telling the car to run lean causing it to bog and heat up the cats
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
Evil_Capri
Sep 11, 2015 08:39 AM
