Sn95 AC QUESTION
Sn95 AC QUESTION
My AC is coming out the windshield and feet even though the dial is set for max to come out the dash vents. The **** is working cause I can turn the system off.
Is this a vacuum leak or what?
Up the hood and look on the drivers side at the firewall near the window and you will see a hard plastic vacuum line. Check and see if it's cracked or broken. This is very common on Mustangs. Mine did and all i did was took cut the plastic line where it was't rotted, cleaned all the old rotten plastic out the rubber grommet, stuck the plastic back in the grommet and put it back on the connector and it was good again. Hope this helps.
Guarantee this is the OPs problem. Had the same issue on my 96 Bronco.
