I swapped the pcm and got new codes
Old Feb 19, 2018 | 04:53 PM
Ruish's Avatar
Lightbulb I swapped the pcm and got new codes
I was having trouble with my cluster and , was very expensive fix it, so I went to the auto wreck and got a pcm / cluster and key / for 2004 mustang v6 automatic.
The car runs but I got problems with the speed , so I put the scanner and got this codes
P1289 cylinder head temperature sensor circuit high input
P0720 Output Shaft speed sensor circuit
I have 2000 mustang v6 automatic.
Someone knows if I did something wrong ? I will need a tuner ?.
Old Mar 30, 2020 | 01:28 PM
fehadz's Avatar
On the off chance that you swap your pcm and the vin and mileage the tech may over look it on the off chance that he isn't told to check for a tune, a few shops approve of it yet FCA isn't. In the event that you hack the PCM and, at that point come back to a stock tune they can tell. Fca can request a sweep and it will raise a code revealing to them it has been messed with. On the off chance that you do anything simply expect you will be mindful and they will likely viod your guarantee.
Tutuapp 9apps Showbox
Matthew Seedorf
Apr 28, 2018 08:52 PM
Blackout
1994-2004 V-6
13
Mar 12, 2013 06:49 PM
holtywsp
May 2, 2012 03:13 PM
don_w
42
May 3, 2006 01:39 PM
