Codes
Old Mar 10, 2013 | 10:00 AM
Blackout's Avatar
Codes
P1100 mass air flow (maf) sensor ckt intermittent
P0602 power train control module programming error
What's these mean?
Old Mar 10, 2013 | 10:36 AM
skunk21's Avatar
P1100 Either the MAF sensor connectors, harness, or an open/short inside the MAF.Check the connection make sure it is tight and clean. I would also try and clean the maf. If that doesn't work then get a meter and check the voltage.
P0602 The VID data was corrupted by the scan tool during VID reprogramming . Using the scan tool, reprogram the VID block. If the PCM does not allow reprogramming of the VID block, reflashing PCM is going to be required.
Old Mar 10, 2013 | 03:48 PM
Blackout's Avatar
Ok so clean maf.
So what's the second part
Old Mar 10, 2013 | 07:07 PM
skunk21's Avatar
Po602 can be caused from a the hand held scanner/tuner not making a connection with the pcm ( a communication error). 602 can show up from a tune. you can try and clear it and see what happens. If the car has a tune there could be a problem with teh tune.
Old Mar 10, 2013 | 08:04 PM
Blackout's Avatar
Alright got ya. I wanna leave sct anyway and go with diablo
Old Mar 11, 2013 | 09:39 AM
Blackout's Avatar
Where could I get a new mass air flow sensor?
Old Mar 11, 2013 | 09:55 AM
skunk21's Avatar
Stock Ford
http://tousleyfordparts.com/ ask for Steve. used them for years.
http://www.rockauto.com/catalog/x,ca...,parttype,5128
Old Mar 11, 2013 | 11:42 AM
MorePowerTuning's Avatar
Former Vendor
I'm curious why you are unhappy with your SCT tuner.
Old Mar 11, 2013 | 11:48 AM
Skunk21 is the shiznit for shore
Old Mar 11, 2013 | 12:30 PM
Blackout's Avatar
Oh god the gangster talk lol
Old Mar 11, 2013 | 12:31 PM
Blackout's Avatar
It's not updated soft ware and the diablo has something newer that I want
Old Mar 12, 2013 | 12:01 PM
Former Vendor
What does Diablo have over SCT?
Old Mar 12, 2013 | 12:06 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Hopefully better customer service? Lol
Old Mar 12, 2013 | 06:49 PM
Blackout's Avatar
Better tuner
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
