How to remove tranny
Old Apr 26, 2013 | 05:40 PM
Blackout's Avatar
How do you remove a 2000 v6 mustang automatic transmission?
Old Apr 26, 2013 | 10:39 PM
1999Pony's Avatar
Remove the driveshaft, shifter and starter. Unplug all the wiring. Then take off the trans bolts. Your gonna need a looong extension and universal to get the top two.
Old Apr 27, 2013 | 03:24 AM
after removing your drive shaft put a plastic bag over the end of the trans and wrap some tape around it. Use a floor jack to hold up the end of the trans and remove the cross member. Then you can jack it up or lower it to make it easiser to get to the trans mounting bolts. If I remember correctly I removed the top trans bolts from under the hood but I had a v8
Old Apr 27, 2013 | 01:15 PM
Blackout's Avatar
Thanks y'all. I work at a machine shop so I will use a hoist to lift it in the air and wrap it. V6 engine and tranny for sale anyone?
Old Apr 27, 2013 | 06:37 PM
bluethunderhorse's Avatar
You've also got bolts holding the torque converter to the flex plate. I can't remember if it's 3 or 4, but they'll have to come out
Old Apr 27, 2013 | 06:57 PM
Is it like the AOD where there's an access plate in the front of the tranny underneath and you have to turn the crank manually to get at each one at a time?
In that case you undo the nuts holding the flex plate to the torque converter and them undo the bolts in the bell housing.
I think you also have to be careful of it tilting down and the torque converter sliding off the tranny. Correct?
Old Apr 27, 2013 | 07:07 PM
sound like he is going to pull the engine and trans at the same time??
Old Apr 27, 2013 | 08:59 PM
Blackout's Avatar
Yes at the same time
Blackout's Avatar
Wow what a transformation...
Antigini-GT/CS
Oct 5, 2015 09:43 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
