Gt nitrous kit
Old Feb 25, 2013 | 07:54 PM
Blackout's Avatar
Gt nitrous kit
http://www.americanmuscle.com/zex-bl...em-8604gt.html
I'd really like to know if I could use this on my car?
Old Feb 25, 2013 | 07:57 PM
1999Pony's Avatar
Probably need to upgrade your fuel pump and injectors, but I dont see a reason why you couldnt.
Old Feb 25, 2013 | 08:08 PM
Blackout's Avatar
I don't want the power all the time being v6 will be the dd. ill buy and turbo the v8 as my track car. I know where I wanna go now
Old Feb 25, 2013 | 08:57 PM
1999Pony's Avatar
Keep the shot between 50 and 75hp and you should have no problems. I wouldn't go any higher then that.
My buddy had a 75 in his SRT-4 years ago. A lot of fun until the bottle runs out lol.
Old Feb 25, 2013 | 09:14 PM
Blackout's Avatar
What power gains with temporary nitrous
Old Feb 25, 2013 | 09:15 PM
1999Pony's Avatar
Depends on the shot. 75 will give you 75 at the crank so probably 60ish at the wheels.
Old Feb 25, 2013 | 09:17 PM
Blackout's Avatar
Enough to keep up with a stock 94-04 gt?
Old Feb 26, 2013 | 07:43 AM
AMDanBailer's Avatar
Former Vendor
This kit will work great on your Mustang! This comes with everything included, nitrous wise but I would recommend a few other things. Definitely go with some bigger Injectors, Nitrous Spark Plugs, Bottle heater and a Fuel pump!
This will allow you to run up to a 125 shot, safely! I hope this helps. Let me know if you have any questions or need some assistance! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Old Feb 26, 2013 | 11:06 AM
Blackout's Avatar
-Dan
Thanks Dan!!!!
Old Feb 26, 2013 | 11:08 AM
Blackout's Avatar
-Dan
Your sure this'll work I have a v6
Old Feb 26, 2013 | 11:19 AM
1999Pony's Avatar
Its not any model specific. The reason its says for a V8 is the fuel system is better then our cars to handle the extra power. Our fuel pumps, injectors, etc won't support the added HP. It would be the same with any mods you did for higher HP, you'd need to upgrade the fuel system.
Old Feb 26, 2013 | 09:42 PM
rodsoccer2's Avatar
With nitrous is it a 1 and done thing or can you use it more than once?
Old Feb 26, 2013 | 09:49 PM
1999Pony's Avatar
You can use it till the bottle runs out. Though prolonged use could have some bad effects.
Old Feb 26, 2013 | 09:59 PM
1999Pony's Avatar
Old Feb 27, 2013 | 01:01 AM
bluethunderhorse's Avatar
Just make sure that when you activate it, that you are at WOT and above 3,000 rpm, or you could evacuate a piston or a valve
Old Feb 27, 2013 | 05:57 AM
rodsoccer2's Avatar
Alright! So you can control how much you use each time?
Old Feb 27, 2013 | 06:29 AM
Dbranham's Avatar
No, but you can change it often, I believe you just switch out the nozzle you want. Most kits come with three different nozzles usually 75, 100, and 125
Old Feb 27, 2013 | 06:41 AM
Blackout's Avatar
Could forged internals outlast nitrous use?
Old Feb 27, 2013 | 07:04 AM
1999Pony's Avatar
Yep
Everything has a limit. They would allow you to increase the amount you use. But they wouldn't let you use it constantly.
Old Feb 27, 2013 | 10:29 AM
Blackout's Avatar
**** I thought nitrous was safe.
