Difference in K&N airfilter & K&N kit
Old Jun 5, 2005 | 10:13 PM
BrIaN_B's Avatar
I am looking into purchasing a K&N air filter for my 1995 convertible muzzy. I was wondering if i should spend a little bit more to get the kit if its worth it, or just stick with the filter. Also, how much will i be looking to spend?
Old Jun 6, 2005 | 10:19 AM
joker's Avatar
I believe the filters run about $50, and the kits run $150. The kit contains the filter, and intake tube from air box to throttle body. The filter may net you a couple of hp, and a little better gas mileage. You probably wont pick up more than 1 or 2 more hp by going to the intake kit unless more of your air delivery path is upgraded as well. (ie, intake, throttlebody, maf) If you plan on doing alot more engine an performance related mods, the get a kit. If not just buy the filter.
Old Jun 6, 2005 | 10:48 AM
1999 Black 35th GT's Avatar
I would just stick with the filter. You really won't notice a difference between the FIPK and the filter without other mods such as a larger TB, perfomance chip, or better intake. The filter is definetley a good idea though for any vehicle!
Old Jun 6, 2005 | 07:49 PM
Dark02Pony's Avatar
as andy said with the TB though to get the full response out of it your best bet would be to to your upper manifold with a port-match for the 70mm or whatever size you'd go for. as for the KN FIPK it gives you the open filter which would of course mean more air and the tube doesnt have any ribs in it which means smoother and better air flow but wont add more then a few hp tops.
Old Jun 6, 2005 | 09:21 PM
BrIaN_B's Avatar
Thanks for the information i was going to buy the filter today but i had to send the car to the body shop. Thanks for the help i am learning a lil more evertime i log onto the site.
Old Jun 6, 2005 | 11:03 PM
Dark02Pony's Avatar
no problem man keep us updated :spin:
Old Jun 8, 2005 | 11:03 AM
Pony Ride's Avatar
I would suggest getting the complete intake system, and then getting a true dual exhaust system. But not more than 2 1/4" pipe unless you plan on some major engine work including a forced air induction system. You'll like the performance gains with a better breathing system, the look of having two exhaust tips coming out the back, and you'll love the sound of the intake and the exhaust together.... much more aggressive.
Old Jun 8, 2005 | 03:11 PM
Thats a nice idea but I think he was looking to keep it relatively cheap per se.
Old Jun 9, 2005 | 09:37 PM
BrIaN_B's Avatar
i was actually looking yesterday and making phone calls to exhaust places around my area and i was just throwing ideas around the guy sayd the borla exhaust was about a grand and he said i can get flow masters for about 350 plus about a hundred dollars to install (any other ideas for exhausts that are good sounding? i hear good and bad raves about flow-master), and if i were to get the intake system how much do u think that would run me if i had somone install it for me i am not hands on with cars but give me a 2x4 and i will build u a house
Old Jun 10, 2005 | 10:05 AM
Dark02Pony's Avatar
as for exhaust its all preferance but for install on an intake system is pretty easy acually. anybody can really install it. Its all a matter of ( with the KN Fipk ) bolting up the MAF to the heatshield and 2 cupplers. very easy. i got my KN intake system for 200 through CarDomain.com
Old Jun 10, 2005 | 10:19 AM
The Deviant One's Avatar
If ya want to go cheap, but want a good sounding exhaust, then try MAC Performance. They have a dual setup that bolts right onto your stock y-pipe. It's costs around 300, but there are some places you can get it for less.
Old Jun 10, 2005 | 01:12 PM
BrIaN_B's Avatar
Picking up my car today from the body shop going to start to make some more phone calls thanks for the help guys! The exhaust is mainly for sound tho right it doesn't make a big noticable difference does it?
Old Jun 10, 2005 | 03:19 PM
Dark02Pony's Avatar
^ exhaust helps more in the long run to help everything flow better same with a cold air intake. the stock exhaust is way too restrictive
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
