Cobra IRS into V6 Chassis?
Old Aug 17, 2007 | 07:58 AM
cadmonkey12's Avatar
Does anyone know if the Cobra Independent Rear Suspension can be installed on a V6 Mustang? Has anyone seen an install?
Also, is it possible to install one in a 1994-1998 V6 Mustang?
Old Aug 17, 2007 | 08:50 AM
Knight's Avatar
Needs to be more Astony
A cobra IRS will fit any mustang from 1979-2004. including the V6.
Its possible you would need a custom length driveshaft depending on aplication.
Old Aug 17, 2007 | 08:52 AM
jarradasay's Avatar
I believe the chassis are all the same. It will probably require a little work and a new driveshaft, but it can be done. The V6 and V8 chassis are the same, so if you buy the V8 install kit you should be able to do it. You will probably also need an ECU tuner to reflash your ECU with the proper gear ratios etc. Your exhaust will not fit either, so you will either need it custom made, or buy an H Pipe and add either a stock or aftermarket cobra exhaust.
Let me know if you go ahead
Old Aug 17, 2007 | 08:59 AM
Knight's Avatar
Thanks I totally forgot about mentioning exhaust change as well
Autotooner
Nov 24, 2017 12:42 PM
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
trackpack13gt
Oct 2, 2015 08:20 PM
blackhawkkid308
Sep 30, 2015 04:04 PM
Ray11
Sep 25, 2015 12:43 PM
