Backfiring after header install help!
Old Jan 10, 2019 | 11:56 AM
Avany's Avatar
If anyone could help me with my issue that would be lovely. I decided to change the exhaust manifold on my 99 mustang from stock to shorty headers and x pipe. l also in the process did an egr valve delete and installed a cold intake. The first time and i started the car it ran fine but sounded like it was off so i checked the wire placement and re-did it and started it again and didn't want to start. than went back to original wiring and started right up but still sounded off. But than when i went to test drive it afterwards it started to backfire which sounds like pops but only when accelerating and decelerating. But at idle it seems to have a hanging idle and idles around 6-7 k. Also when putting the car into gear(automatic) it seems to bog down when under-load and the rpms drop to 5k. I have also seen that my fuel economy drop because i have to fill it up every two to three days. I think the car needs to flashed. Can anyone help? Only car.
Old Jan 11, 2019 | 07:51 AM
possible vacuum leak. Check all your air intake connections and the seal on the egr valve
Old Jan 11, 2019 | 09:24 AM
Avany's Avatar
the new headers i put on dont have a connection for the egr so i deleted the egr. Would deleting the egr cause the backfires along side with the high flow headers and x-pipe?
Old Jan 11, 2019 | 11:11 AM
SpectreH's Avatar
How did you plug where the EGR connected?
Old Jan 11, 2019 | 12:10 PM
Avany's Avatar
I just used a block off plate with a gasket. Im waiting for a flash tuner so i can turn of the egr system and tune the car because it is running really rich.
Kevn
Jul 12, 2016 11:38 AM
d_bone33
Oct 14, 2010 07:16 AM
n8rfastback
Nov 25, 2008 10:02 PM
92lx5.0
Mar 22, 2007 05:36 PM
Punisher85
May 19, 2005 09:17 PM
