About to get the daughter a 2003 V-6
I had one for that long.....traded it in at 72,000...FAntastic car....had a fuel pump go out at 30,000....then nothing but Awesomeness...
One thing you might want to check out is the PCV valve, just to make sure you are getting good suction through it. I know that was an issue with the 00's....
I'm just about to turn 80k on my 2000 v6 and I couldn't be happier.
Actually having a higher mileage with a newer car may not be that bad after all, it can't all be city miles which are VERY hard on cars. Interstate/highway miles are easy miles. If all you did was drive 100 miles a day on the interstate, I bet the drivetrain would last 300K miles no problem. (with many tires/shocks/oil changes/other small maintenance items)
You need to peak underneath the back of the car and decided if the gas tank is in a location where she will be safe if rear ended.
thats probably the strangest of all things that could have been said.. all of the 99-04 stangs have the gas tank in the same location so whats the difference.. this hasn't been an issue with these cars from my understanding.. i heard about this a very very limited number of times with the crown vic interceptors b/c cops are always pulled over on the side of the road..
That's the first thing that I thought of, as well.
How do you check for that???
The PCV valve is on the drivers side of the engine. Basically you have to pull the valve out while the engine is on and put your finger up to the open end. There should be a ton of suction there...if there isn't you need to replace the PCV valve or the entire assembly....this is where it is:
http://i119.photobucket.com/albums/o...g/102_1075.jpg
This is the whole assembly:
http://i119.photobucket.com/albums/o...g/102_1076.jpg
Hope that helps!
Hope that helps!
I have a 96 V6 I bought brand new overall it has been a great car...I've never had to do anything major to it...I wish I could say the same for my new 06 SALEEN it has basically been in the shop since brand new one thing after another....
I have a 2003 ZX2 with 75.000 miles and not a single problem. With a high mileage 'newer' car there are less problems to be aware of. My ZX2 runs like a dream and would sell it to my own family.
I would certainly consider it for your daughter, just check it out thoroughly, give it a good test drive and hope for the best.
I would suggest that if you do buy it change all fluids and filters even if they dont need it and start routine maintanence as you mean to go on.
Good luck.
Good luck.
No doubt, thats just crazy talk...all the '79-'04 Mustangs tanks were bolted in the same place, never a real issue at all, geez.
