About to get the daughter a 2003 V-6
Old Oct 18, 2006 | 04:59 PM
traffic142's Avatar
Any problems I need to know about?
It has 72,100 miles on it.
Old Oct 18, 2006 | 05:18 PM
codeman94's Avatar
I had one for that long.....traded it in at 72,000...FAntastic car....had a fuel pump go out at 30,000....then nothing but Awesomeness...
Old Oct 18, 2006 | 05:33 PM
SteelTownStang's Avatar
I know she'll be happy
Old Oct 18, 2006 | 05:53 PM
LEO_06GT's Avatar
My only worry would be the amount of miles. It's about to be a four year old car and already has 72,000 plus miles on it. That's above avearage.
Old Oct 18, 2006 | 06:04 PM
PaulF's Avatar
That's the first thing that I thought of, as well.
One thing you might want to check out is the PCV valve, just to make sure you are getting good suction through it. I know that was an issue with the 00's....
I'm just about to turn 80k on my 2000 v6 and I couldn't be happier.
Old Oct 18, 2006 | 08:44 PM
Silver99v6's Avatar
Mine is a 99 with 48K on it and the only problem that Ive ever had is getting bad gas.
Old Oct 18, 2006 | 09:50 PM
PaulF's Avatar
Oh! I forgot...you might want to see if it has the original fuel pump (and filter) and replace. I've heard of a few people having knocking issues in the SN95's around this milage, due to a bad fuel pump.
Old Oct 19, 2006 | 03:43 AM
theedge67's Avatar
Actually having a higher mileage with a newer car may not be that bad after all, it can't all be city miles which are VERY hard on cars. Interstate/highway miles are easy miles. If all you did was drive 100 miles a day on the interstate, I bet the drivetrain would last 300K miles no problem. (with many tires/shocks/oil changes/other small maintenance items)
Old Oct 19, 2006 | 11:02 AM
T Town Bobby D's Avatar
You need to peak underneath the back of the car and decided if the gas tank is in a location where she will be safe if rear ended.
Old Oct 19, 2006 | 11:16 AM
07ShelbyWanter's Avatar
thats probably the strangest of all things that could have been said.. all of the 99-04 stangs have the gas tank in the same location so whats the difference.. this hasn't been an issue with these cars from my understanding.. i heard about this a very very limited number of times with the crown vic interceptors b/c cops are always pulled over on the side of the road..
Old Oct 19, 2006 | 11:36 AM
DrunkenDragon713's Avatar
It was also an issue with the 1st generations (or so I've heard) but after 1971, they made the tanks less likely to explode in case of a rear end.
Old Oct 19, 2006 | 08:17 PM
traffic142's Avatar
How do you check for that???
Old Oct 23, 2006 | 07:57 AM
PaulF's Avatar
The PCV valve is on the drivers side of the engine. Basically you have to pull the valve out while the engine is on and put your finger up to the open end. There should be a ton of suction there...if there isn't you need to replace the PCV valve or the entire assembly....this is where it is:
http://i119.photobucket.com/albums/o...g/102_1075.jpg
This is the whole assembly:
http://i119.photobucket.com/albums/o...g/102_1076.jpg
Hope that helps!
Old Oct 31, 2006 | 08:40 PM
06SALEEN1246's Avatar
I have a 96 V6 I bought brand new overall it has been a great car...I've never had to do anything major to it...I wish I could say the same for my new 06 SALEEN it has basically been in the shop since brand new one thing after another....
Old Nov 8, 2006 | 01:35 PM
Zastava_101's Avatar
TMS Post # 1,000,000
Serbian Steamer
What is asking price on that Mustang?
Old Nov 8, 2006 | 01:36 PM
Serbian Steamer
I have '00 Mustang V6, 5 speed with 41,000 miles.
I had one problem with theft system, but everything else is great.
Old Nov 10, 2006 | 07:23 AM
tricky02GT's Avatar
I have a 2003 ZX2 with 75.000 miles and not a single problem. With a high mileage 'newer' car there are less problems to be aware of. My ZX2 runs like a dream and would sell it to my own family.
I would certainly consider it for your daughter, just check it out thoroughly, give it a good test drive and hope for the best.
I would suggest that if you do buy it change all fluids and filters even if they dont need it and start routine maintanence as you mean to go on.
Good luck.
Old Dec 6, 2006 | 09:39 AM
TJ4Cam's Avatar
No doubt, thats just crazy talk...all the '79-'04 Mustangs tanks were bolted in the same place, never a real issue at all, geez.
Old Dec 9, 2006 | 08:02 PM
tricky02GT's Avatar
Did you end up buying the car for your daughter????
Old Mar 11, 2007 | 02:57 PM
traffic142's Avatar
yes I did
