2000 3.8 Convertible (Psgr Door Window)
Greetings:
New here... working on fixing up a 2000 convertible. Has a bad window regulator motor and psgr window was broken. Cleaned out all the glass and found some black ****-like hardware with glass attached. Does that come "stock" on the replacement glass?
Was thinking about trying to get at my local pick a part yard....
Does anyone know if the convertible model is interchangeable with the coupe and GT versions for glass purposes? (still learning here...)
Thanks in advance for any feedback...
The reconsidered 1 piece section on this window is likely why anybody will be searching for new glass shy of a messed up window. The manufacturing plant window is 3 pieces stuck to the window at the most elevated pressure influence focuses and furthermore go about as stops. Perpetually, the paste comes up short and the sections tumble off and that is the reason your window tumbles down in the entryway or is all out of alignmnet or whatever.
Kodi Lucky Patcher nox
