2000 3.8 Convertible (Psgr Door Window)
Old Jun 11, 2017 | 04:32 AM
rvac334's Avatar
Greetings:
New here... working on fixing up a 2000 convertible. Has a bad window regulator motor and psgr window was broken. Cleaned out all the glass and found some black ****-like hardware with glass attached. Does that come "stock" on the replacement glass?
Was thinking about trying to get at my local pick a part yard....
Does anyone know if the convertible model is interchangeable with the coupe and GT versions for glass purposes? (still learning here...)
Thanks in advance for any feedback...
Old Mar 30, 2020 | 01:29 PM
fehadz's Avatar
The reconsidered 1 piece section on this window is likely why anybody will be searching for new glass shy of a messed up window. The manufacturing plant window is 3 pieces stuck to the window at the most elevated pressure influence focuses and furthermore go about as stops. Perpetually, the paste comes up short and the sections tumble off and that is the reason your window tumbles down in the entryway or is all out of alignmnet or whatever.
Kodi Lucky Patcher nox
wheelman1
Mar 31, 2012 09:15 AM
Ramstang
1994-2004 V-8
Feb 11, 2012 08:34 PM
hessy
Mar 22, 2007 08:11 AM
porkster
May 17, 2006 10:15 PM
Dineau
Nov 3, 2005 09:45 AM
