05 V6 16" factory wheels/tires
Old Apr 20, 2005 | 09:17 PM
toronado's Avatar
Anyone know if take-off wheels and tires from an 05 V6 will fit on either of the two previous generations of mustangs?
I had a 99 V6 two cars before I got my 05 V6 and the standard factory wheels were tiny 14" junk wheels with huge plastic center-caps. Would buying cheap 16" take-off wheels from an 05 V6 be a good mod idea for owners of previous stangs?
Old Apr 20, 2005 | 10:15 PM
Dark02Pony's Avatar
from what i understand the 94 - 04 wheels are a slight bit differant from the 2005+ wheels when it comes to being able to bolt right on
Old Apr 21, 2005 | 09:20 PM
DanS.02GT's Avatar
The bolt pattern is the same, but the offset is different.
Old Apr 21, 2005 | 09:41 PM
pilot1129's Avatar
whats offset?
Old Apr 21, 2005 | 11:07 PM
Dark02Pony's Avatar
distance from the hub mount surface to the center line of the wheel..heres photo for ya to look at incase you dont understand that
Old Apr 22, 2005 | 05:21 PM
jgsmuzzy's Avatar
I looked into this and was told that the standard 2005 V6 wheels would not fit, rubbing and all that.
Old Apr 29, 2005 | 10:26 PM
s7v7n's Avatar
That is correct. The 05 wheels are designed for 05 only...you could make it work...but it just isn't worth it, and wouldn't look that great :nono:
Old May 18, 2005 | 02:22 PM
Vermillion98's Avatar
What exactly is the offset of the 05 V6 wheels? I've run 0 offset 15X7 wheels and 225/60/15s on my '98 before and had no clearance problems at all.
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Feb 10, 2017 07:12 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
