What gears to get?!?
Old Sep 13, 2011 | 08:02 PM
mdcooper82's Avatar
I Have a 1990 lx 5.0 thst is stock. Only 67,000 miles. What gears do you recommend to speed it up a bit? I plan on doing MAF. TB. Next. Just starting out with gears?
Old Sep 18, 2011 | 09:14 AM
delz05's Avatar
What gear ratio do you have? 5speed or auto?
To go faster, add a turbo or supercharger, to get more "off the line" pull, you do gears, which will actually reduce your top end speed.
Stock gears range from 2.73, 3.08, or 3.27. Going to 3.55s or 3.73s will be nice, but will not add speed, just quickness.
Old Sep 20, 2011 | 03:14 PM
mdcooper82's Avatar
I'm sorry, it's an automatic. I'm
Just wanting more power off the line.. No top end. I don't plan on racing it.. I drive it to work everyday.. Some city and some highway.
Thinking 3.55 or 3.73. Am I going to need a new speedo?
Would 4.10 be too much for an all stock automatic? Would highway be terrible?
I basically want to floor it and the tires easily break loose.. It will not break loose right now unless I gun it through a turn.
Thanks guys!!
Old Sep 21, 2011 | 06:41 PM
mdcooper82's Avatar
Think I'm gonna go with 3.73
Old Sep 23, 2011 | 07:17 PM
matt90lx's Avatar
I put 410's in mine, and cruising at 70 I'm at about 2500 rpm, off the line it's awesome, but for a daily driver I would go with a 3:73. I'm sure you'll get a nice increase in acceleration and still be able to go down the highway
Old Sep 23, 2011 | 08:43 PM
Kona Blur's Avatar
My buddy's 92 DD has 3.73s and it's perfect for him... As awesome as 4.10s are, may be a little much for a DD...
Old Sep 23, 2011 | 10:22 PM
I'm considering this for my '91 also. I've got an AOD. Not sure of the gears. I just started considering a T5 swap, but in either case I want new gears.
Old Sep 24, 2011 | 08:06 PM
mdcooper82's Avatar
Yeah I got the 3.73. Im on the highway everyday so I think those will be best. I though about switching it over to a manual... But **** that's a lot of work for a weekend! Lol. This is my only DD for now.
Whats a highly recommended throttle body.. Or what else could I do to speed it up.. Fairly cheap? It has a k&n cold air.. Not sure about the MAF, and flowmasters. other than that it's stock.
Old Sep 26, 2011 | 02:24 PM
Tirefryer's Avatar
My 93 lx has 3.73 and i travel all over the us for work 2800 at 75 and top speed of 130 mph. Highly recomend 3.73.... And just get a garmin gps to fix ur speedo that way u can change tires as well....tires will spin on demand...
Old Sep 28, 2011 | 09:47 PM
Boss89's Avatar
When you change your gears you also need to change the little plastic gear on the end of the speedo cable where it goes into the transmisson. It is pretty easy to change. You just need to swap for the right one to match your new rearend ratio to keep the speedo accurate.
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
