tps adjustment- how to
Old Oct 10, 2007 | 08:10 AM
Fordracing200's Avatar
can someone give me the how-to on the tps adjustment mod
thanks
Old Oct 10, 2007 | 10:13 AM
tps??
Old Oct 10, 2007 | 11:22 AM
throttle position sensor
Old Oct 10, 2007 | 11:30 AM
Evil_Capri's Avatar
How's this . .
How To Adjust TPS
"Muscle Mustangs & Fast Fords"
April 1993
The throttle position sensor is one of those things that falls
into the category of "computer stuff" that makes a big difference
and is easy to deal with, but average people like us would never
know about. Without the proper adjustment, the throttle position
sensor (TPS) will give the computer a false reading as to the
exact throttle opening. A false reading will limit wide open
throttle performance (something we definitely don't want). A
voltage reading must be taken using a digital volt/ohmmeter
(DVOM) with the Key On/Engine Off and with the Key On/Engine
Running. A Radio Shack DVOM, part No. 22-185A, works well for
this job.
The TPS is located directly on top of the throttle body and is
adjusted by loosening the two phillips mounting screws and
swiveling the sensor until the highest reading is found. It may
be necessary to elongate the holes with a small file to achieve
the desired reading.
The spec range for Key On is from .88 to 1.0 volt; shoot for the
.97 to .99 volt. With the engine running, the voltage should be
no higher than 1.05 volts.
Incorrect Throttle Position Sensor (TPS) voltage will result in
reduced performance. The best way to take a TPS voltage reading
is by using two safety pins through the wires coming from the
sensor. The positive lead is attached to the green wire, while
the negative goes to the black wire. Always ground the meter
through the sensor's black wire. This gives a direct, and more
accurate ground into the computer.
http://links.vintage-mustang.com/FAQ...Generation.txt
Old Oct 10, 2007 | 02:42 PM
thanks a million! I knew I could rely on this site!, I'm mod'ing up the new truck, just got done two toning it with spray on bedliner on the bottom, taillight covers, flowmaster catback with big rolled lip baffeled tip, etc. etc.
kennyg
Aug 14, 2023 11:45 AM
Fastryker
Aug 7, 2015 05:28 AM
devildog1679
May 1, 2012 10:02 AM
