Thinkin of makin the switch....
Old Jul 17, 2005 | 09:21 AM
Ren 89's Avatar
I'm thinkin about converting my rear drums to disks on my 92. Has anyone done this, was the switch diffucult? If anyone has any helpful insight or has a conversion kit they would recommend, let me know. Thanks
Old Jul 17, 2005 | 09:44 AM
63galaxie's Avatar
You can convert your car to four discs and fuve lugs...get a 94-98 mustang, it can be a V6...its a bolt on pretty much
Old Jul 17, 2005 | 07:14 PM
scottie1113's Avatar
Yeah, easy to do, and well worth the cost and effort. You don't want drums on your Mustang.
Old Jul 18, 2005 | 08:35 AM
1999 Black 35th GT's Avatar
If you are going to mod your Stang in any way this is the first step you should make. Good thinking. A lot of people will hop up their cars without first thinking about handling and braking. Make it stop, make it handle, then make it go!
As for kits, like 63 Galaxie said you can find a 94-98 V6 for the five lug conversion or if you can find a junked SVO 85-86 Mustang they had rear disc in the Four lug format. You will also probably need a new master cylinder for the mod.
If you want new you can go to 5.0 Resto for a new kit. Heres the link and good luck and have fun:
79-93 Rear Disc Brake Conversion Kit
Old Jul 18, 2005 | 08:56 AM
63galaxie's Avatar
My Mustang has drums in the rear, and its four lug. It brakes weak right now because of the master cylinder, but there are fox body's running nine's with fourlugs, and i bet some have drums. I see a lot of people changing to fivelugs
Old Jul 18, 2005 | 02:55 PM
Ren 89's Avatar
Thanks fella's, I appreciate any input you send my way....
Old Jul 19, 2005 | 08:42 AM
Coupe's Avatar
IMHO, it depends on what you plan on doing with the car. Road racing, straight line, or driver. 4 wheel disc on a driver (with occasional romp) is over-kill. Most of your braking force is on the front spindle anyways, when looking at brake bias I haven't experience (rear drum) brake fade, but I'm not road racing in stop-n-go freeway traffic either.
If you are planning on converting to 5 lug rear, you'll need to convert the front to 5 lug also, if you want to be able to rotate tires. As 35th GT stated, you can convert the rear, and keep your 4 lug with that kit. A wrecked/junked SVO might be a difficult find
For the price of that kit, I'd look at changing/replacing rear suspension pieces, beefing up the front rotors, and adding some sub-frames. But hey, thats just me. I'm married with children!
Old Jul 19, 2005 | 10:02 AM
svopaul's Avatar
Service Manager
Don't bother searching for an SVO for the disc brakes....just find a Mark VII Lincoln...same exact brakes and you can buy the SVO E brake cables through NAPA for about $40 each. But remember they are 5 lug...if you want to go 4 lug then you need to get the axles/brakes from an 87-88 Tbird Turbo Coupe.
Old Jul 21, 2005 | 05:09 PM
PACETTR's Avatar
This was very helpful when I did mine...
http://mjbobbitt.home.comcast.net/mustang/5lug.html
Old Jul 22, 2005 | 04:32 PM
Ren 89's Avatar
Just thought I'de take a second and thank you fellas for all the advice...the pro's and con's...what a where to look...etc,etc....I think for now I'm stayin with the drums and puttin the money toward I few minor cosmetic details that seem to stick out..(at least to me they do)....once again, thanks.
polodinks
Sep 3, 2008 10:32 PM
Redrocket06
Which is Better
33
Jun 24, 2008 10:40 AM
RFLgtcs
Nov 20, 2007 01:46 PM
King Taco
V6 Performance Mods
Sep 24, 2007 03:07 PM
StangerX
V6 Performance Mods
Jul 25, 2005 04:52 PM
