Seeking Valve Cover gasket instructions
Old Apr 10, 2012 | 09:38 AM
srobertson0057's Avatar
Hello mustang enthusiasts I'm a novice when it comes to mechanical work, I can pretty much only do bolt on assembly work. I need to replace the valve cover gaskets due to an oil leak on the front left side above the oil filter and in the back of the 302 engine. Now it seems the upper intake has to come off and all the vacum hoses plus wires. Does anyone have good instructions from disassembly through reassembly valve cover gasket intstructions or perhaps a link to some instructions? Thanks guys.
Old Apr 10, 2012 | 04:24 PM
skunk21's Avatar
Link to remove the upper intake:
http://www.allfordmustangs.com/Detailed/2007.shtml
You don't indicate what year you have but this the vlave cover gasket I would use:
http://www.latemodelrestoration.com/...-Cover-Gaskets
Don't over tighten the gasket. It is only just about hand tight or about 5ftlbs of torque on the valve cover bolts. If you use the above gasket it is really hard to over tighten them with the metal core so don't crank the bolts. use a pattern and then just go over them again real quick.
Old Apr 10, 2012 | 06:39 PM
matt90lx's Avatar
If you are planning on doing further repairs/upgrades, a haynes or chiltons repair manual would be your best friend, I've used them and I think they are great
Old Apr 11, 2012 | 08:50 AM
Thanks guys. I have a 90 LX 124,000 miles use as my primary horse (daily dtiver). Ordered the book on Amazon along with a 5.0 projects book
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
samjluck
Sep 17, 2015 10:24 PM
Beouch
Sep 16, 2015 06:14 PM
