Restoring fender shrouds write-up
Old Oct 8, 2009 | 08:52 PM
MunkeyOnTheLoose-witha5.0's Avatar
-I did this a couple years back(2003) and found the photos to it so i figured I'd do a write up.
-Fresh shrouds from Ford in 2003(the last year they sold em) were going for $170 which seemed excessive to me at the time and I deceided to revitalize them myself with about $20 worth of products and some time.
-First off my fender shrouds are OEM and have had overspray, tar, and nicks all over them. This is what i started with:
You can see where the tar has been caked on for awhile......actually the car go repainted in 94' and some of this tar has overspray on it!
After some careful consideration I had to remove the tar without scuffing up the plastic and so i chose to do the following:
Step 1: Removing the fender shroud is MUCH easier without the wheel in the way for obvious reasons. It can be done without moving the wheel out and just jacking the car up to create clearance between the top of the tire and the fender. There are clips that secure the shroud to the frame and screws that secure the outboard edge to the fender lip. Remove these screws with the proper phillips screwdriver and remove the clips with one of those fancy clip remover tools.....or as most of us do it...with the needlenose pliers we have lying around. Be warned though!!! Removing with needlenose pliers might result in damaged clips which cannot be used and you will need to purchase a few new ones at about $1 a pop. After all retaining clips are removed you should be able to wiggle the shroud out.
Step 2: Using gasoline(it was about $1.20/gal at the time) I massaged the shroud with some paper towels making sure to wear gloves and a mask until all the little "nuggets" came loose. I used about 10 sheets of paper towels and about half a gallon of gas. This is what it looked like just after the rub:
Notice how the tar is all gone and the plastic itself is unscuffed from abrasive substances/brushes and the color is still even.
Step 3: It's time to sandpaper!!!! I used 800 Grit(i think it was the finest i could find at the time) and LIGHTLY scrubbed the surface. I did this evenly for about 15 mins making sure that i could see the very tiny scrape marks up close but at a distance they were invisible.
Step 4: Using a "Flexible" paint since the shroud will flex at times you should lightly coat the fender shroud evenly until it is barely covered. Let it sit in warmer weather for about 20-40mins. This is what my first coat looked like:
Apply 2-3 or even 4 more light coats as desired making sure to evenly coat the plastic and avoid spraying excess in corners or tiered areas to prevent clumping.
Step 5: Sit back and enjoy your fresh new fender shroud that you just saved $100 bucks on!
You can reinstall the opposite of the way you uninstalled it but I would seriously recommend taking off the wheel this time to prevent damaging your freshly painted shroud. You wouldn't believe how much of a difference it makes! Especially on an older vehicle. This is what mine looked like re-installed:
Cheers!
Old Oct 8, 2009 | 09:20 PM
Looks great. Thanks for posting.
Old Oct 8, 2009 | 10:16 PM
Blue Notch's Avatar
I need to do this.
Old Oct 9, 2009 | 03:07 AM
DrunkenDragon713's Avatar
Chris, don't you have to do this again?
Also, before you ever take that car to a shop to get worked on b/c you don't have a tool, let me know. Joey has a lot of tools left over from building the Cobra kit car that he might let you borrow.
Old Oct 9, 2009 | 03:27 PM
STL-GT's Avatar
I did something very similar when I did the front brakes on my black GT. Didn't end up painting them tho - just spayed them a few times with tire shine and they look brand new. Its amazing how much better it makes the whole wheel well look.
Thanks for posting!
Old Oct 9, 2009 | 07:49 PM
I've done that with an engine bay before. But, it attracts dust a lot more too.
Old Oct 10, 2009 | 07:31 AM
STL-GT's Avatar
Very true, but it repels water pretty nicely!
Old Oct 11, 2009 | 09:29 PM
Chris and I had a conversation yesterday, and we agreed that this Step constitutes a warning.
Please, do not smoke while doing this step.
Thank You!
Mustang65bob
Sep 21, 2015 11:30 AM
DEPUTY62
Sep 12, 2015 11:12 AM
GMAYS
Sep 10, 2015 06:19 AM
Jul 28, 2015 07:04 AM
