Radiator fluid
Radiator fluid
Have an 85 5.0 and I have radiator fluid dripping on the passenger side.. Radiator hoses are fine as well as the water pump. The whole engine bay is dry. Inside of my car is dry so I dont think it's the heater core. Any ideas?
take a look down on the fire wall, there is weep hole/drain. if you see antifreeze coming out of it then you have the early signs of a heater core problem..they can start to leak outside also. also take a look around where the heater hose connections are coming in/out ( you may need a mechanics mirror to get a good visual). but look along the fire wall I have a suspicion.
