Power steering flush?
Old May 3, 2012 | 07:35 PM
Sgorsuch77's Avatar
Anyone on here ever do a power steering flush? I have no clue how to i have a 93 mustang 5.0 any help is appreciated.
Old May 3, 2012 | 07:55 PM
skunk21's Avatar
Very easy to do:
Get yourself enough fluid ( type F tranny fluid) and a drain pan. disconnect the low pressure line of the p/s pump ( it is the rubber hose with clamp the rubber/hard line that is screwed in is high pressure). I cap off the nipple in the p/s pump ( rubber caps can be found in the help rack of most parts stores or just ask should be 3/8). I like to bump the motor vs running it so pull the coil wire and spin the motor over to pump out the old fluid into the drain bucket, keep adding new fluid so you do not run the pump dry. keep going until it gets pretty clean. reattach the low pressure line and make sure the p/s fluid level is topped off. hook the coil wire back and run the engine turning the steering wheel full lock left/right a bunch of times to bleed air out and move fluid around. recheck the level. you should be good
Old May 3, 2012 | 08:12 PM
Sgorsuch77's Avatar
Thank you sounds easy enough
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
ricky1728
Feb 11, 2016 07:25 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
